Results 1 to 12 of 12
Thread: Whats needed for an SQ car to be competitive?
    HSV VP Senator
    May 2006
    3rd planet from the Sun...
    Default Whats needed for an SQ car to be competitive?
    This may seem like a stupid post but I am curious..... What is really needed for Sound Quality comps??
    Does it really matter about how much u spend on your equipment or is it just the way it's setup that matters......cheers
    Lets work as a TEAM and do it MY WAY!!
    semi is offline GOD
    VR exec wagon
    Aug 2005
    WA
    Once you get up into serious SQ, both equipment and setup play a huge role in it. You cant really get away with cheap gear, nor can you get away with a cheap install
    Tasmaniak's Avatar
    Tasmaniak is offline Not a valid input....
    car
    Apr 2005
    Setup is probably the biggest part of the game but on that same hand if you ain't got shit then you aint got shit.
    Careful selection of equipment is necessary. Don't just buy a pair of splits because they were the most expensive brand on the shelf. Do the specs line up with the style of music intended to be played through them?
    Do you listen to various styles of music? If so....forget about high end SQ.
    davey g-force's Avatar
    davey g-force is offline I'm a sceptic...
    Phantom MY09 VE SSV A6 & Holden Cruze CDX M5
    Sep 2005
    "...the winner is..."
    Quote Originally Posted by 12Voltking
    What makes you say that?
    Quote Originally Posted by CSP (aka Rufys) View Post
    Look, all the update is going to be is like going from VX to VY or VY to VZ. Same car with different front/rear ends and updated interior. But it will be the VF, not the VE II.
    Tasmaniak's Avatar
    car
    Apr 2005
    Different styles of music require different Eq settings and often times wiser speaker selection.
    It's not a case of "Close enough is good enough" it has to be spot on.
    For instance, if I was to listen to classical music all the time then I would have a set-up consisting mainly of 1", 3", 5" 8" and a 10" subwoofer. Yet, if I was to listen to electronic music then I would probably use a set up like... 1" 6" and use a 10" or perhaps a 12"
    Lets put it into other terms. Lets say you like driving tight twisty corners. Would you buy a 800Kw monster or are you going to go for a Subaru with AWD? Now reverse the situation, if you live to drag....why would you buy the Subaru when you have the 800Kw option?
    Both vehicles can do both jobs. But one can exceed in an area that the other one can't.
    So, if we tune the Subaru to handle extremely well then when we want to drive the straight line as fast as possible it's not really doing it to the best of it's ability if it had've been tuned for drag then it would be a different story.
    Sep 2005
    Yeah I understand all that, but why can't you setup and tune your system for say electronic music and then play that style of music at the SQ comp? Or do they make you play different styles?
    semi is offline GOD
    VR exec wagon
    Aug 2005
    WA
    read that and see if you can figure it out
    VY SS
    Aug 2004
    SE Victoria
    Quote Originally Posted by davey g-force
    no its not that, its just that a system setup for classical will have different speakers (sizes and just plain different models/brands) to something for synethesised music.
    also box volumes, x-over points (the type of x-overs) and the whole frequency curve would all be different, not to mention heaps of other things.
    sure you can take the car to a sq comp and play your selected music to show the system off to its best BUT if you listen to a different style of music on the weekends or while driving then the SQ will be worse than the sq of the system when its playing music it was designed for.
    Sep 2005
    Aaaah ok. Thanks garfa!
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    VY SS
    Aug 2004
    SE Victoria
    Quote Originally Posted by StoneX
    Also, they have a reference test CD that they use to assess your system.
    thought so but i was not sure that all SQ comps are like that. i know stuff all on the topic!
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    I only know about CAASQ... Not sure what other formats there are these days.
  1. Whats needed to lower mr VR?
    By djlingard in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-01-2007, 01:52 AM
  2. Whats your MSN saying?
    By cunners3 in forum The Pub
    Last Post: 22-06-2006, 07:59 PM
  3. lowering a car.... properly whats needed?
    By PaRaDoX in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-12-2005, 07:33 AM
  4. Whats Been Taken??
    By fabz in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-10-2005, 06:03 PM
