Results 1 to 7 of 7
Thread: Amp installation?
    Philthy's Avatar
    Philthy is offline That dent guy
    VS Berlina, XC AMS Project
    Aug 2005
    Default Amp installation?
    HI all, i am installing an amp in my VS exec and i know there should be a grommet where da clutch cable would be (its an auto) but I cant find it.
    Also, is this the best place to run the power cable or should i do something else?
    Any help would be much appreciated...and pictures would be nice since im definately no expert
    Philthy's Avatar
    Aug 2005
    VS Acclaim S2
    Nov 2005
    Hi there dude, the clutch grommet is OVAL SHAPE. It's just a piece or rubber which will not have ANY WIRES running through it at all if it's an automatic. Yes, this is probably the easiest grommet to use as there is plenty of space. Have a look on your firewall, and think where the clutch would be if it was a manual. You should be able to find it, it's the only oval shaped grommet on the firewall.
    Once you've found it, make a slit in it with a knife, probably a bit smaller than the cable you plan on running through it. Then get out some WD-40 (or KY Jelly - whatever is around) and use it on the grommet/cable to allow you to slide it through the grommet. That way it should fit in there nice and firm and not let any water in. Let us know how you go, cheers, Bryce.
    90 VN SS 5speed, '90 VN Calais 5speed
    Jan 2006
    stanthorpe, qld
    i ran my power cable through the clutch grommet.
    i dont have any pics though i will have to take some when i get home. unless someone has beaten me to it
    Adam
    VY SS
    Aug 2004
    SE Victoria
    do a search, heaps of pics.
    or look in the how to section and look at pics of a VS engine bay.
    Philthy's Avatar
    Aug 2005
    Thanks for all your help, but I ended up taking it to a friend and he helped me with it
    It worked well, but getting the wires under the skirting thing was a pain. Looks good now though with no wires in sight
    VT Berlina wagon 5.0 litre
    Jan 2006
    i put mine through the clutch gromet.......i assume it is the easiest way.......was easy for me.
  1. 6x9 installation
    By kingvt in forum Car Audio
    Last Post: 01-10-2008, 10:59 AM
  2. VS amp installation
    By vsMick in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-10-2006, 02:22 PM
  3. lpg installation
    By stackner in forum General
    Last Post: 05-08-2006, 04:45 PM
  4. CAI installation
    By Haze in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-02-2006, 11:07 PM
  5. Sub installation
    By navyboy85 in forum Car Audio
    Last Post: 08-02-2005, 10:35 AM
