Results 1 to 16 of 16
Thread: Can a VT Berlina have steering wheel controls installed?
    gweymouth Guest
    Default Can a VT Berlina have steering wheel controls installed?
    Hiya,
    I have a VT Berlina 99 SII. I really want steering wheel audio controls like on the Calais.
    I rang a dealer who said it's be a $1,000+ job because the cable from the streering wheel controls doesn't just go straight into the HU; that it goes through some computer which would need to be replaced.
    I've searched and searched the forums for an answer. There's plenty about the CAT08 and non standard HU's, etc, but nothing I can find that answers this question.
    Any ideas?
    ScottB_33's Avatar
    ScottB_33 is offline Go Hard or Go Home
    VTII Berlina Supercharged
    Oct 2005
    Nowra
    There's a number of parts you do need but it is not that expensive at all, as I have done it and have covered posts on it also. You can ring me for details if you wish on 0412045372 and check my posts under the headings for steering wheel controls. Very easy to do once you know the details. I would say dealer just didnt want to have any trouble and didnt want the job!!
    gruntavt's Avatar
    gruntavt is offline HSV-I Don't want one ;-)
    vess-luckily
    Sep 2005
    WAGON MAN's Avatar
    WAGON MAN is offline Gas Sleeper
    VX S2 Berlina Wagon with Phreddied bits.
    Jun 2006
    North Coast , NSW
    Quote Originally Posted by ScottB_33 View Post
    Here is the thread
    I like my roo well done
    VY SS
    Aug 2004
    SE Victoria
    Quote Originally Posted by gruntavt View Post
    easy job.
    yes so thats a $1000 plus job for holden!
    Doctor Bob's Avatar
    Doctor Bob is offline Grandpa
    VT V6 Exec & VN V6 Exec
    May 2004
    Mornington Peninsula
    they probably mistakenly believe the signal goes through the BCM as well
    its really a simple job.
    Rob
    VS Berlina Series 2 V6
    Sep 2006
    Hi Scott,
    Could this set up be done on my VS Berlina series 2?
    Struggo
    semi is offline GOD
    VR exec wagon
    Aug 2005
    WA
    I beilieve that you could do it, i dont think that it goes through the BCM. You would probably need to have a HU the same as the one in the calais or another car with steering wheel controls
    VTS5's Avatar
    VTS5 is offline TechJunkie
    '97 VT Spack 5 Speed
    Jul 2005
    Sth.East\Melb
    Does any1 know where can i get one of these modules for my VS? Apperently GM dont stock'em any more.I've already got the steering controls.
    Doctor Bob's Avatar
    May 2004
    Fr3ak+--'s Avatar
    Fr3ak+-- is offline Closed On Monday
    Vt Exec 5 Speed
    Jul 2006
    Kingswood, Nsw
    VTS5's Avatar
    Jul 2005
    Sth.East\Melb
    Quote Originally Posted by Doctor Bob View Post
    ummm ive got a couple...
    can i have one?Also,do i need a loom ?
    VTS5's Avatar
    Jul 2005
    Sth.East\Melb
    Quote Originally Posted by Fr3ak+-- View Post
    u need to have the right head unit to do it
    Well,its '97 Series II equipe,head unit is factory one with cd changer controls.
    Doctor Bob's Avatar
    May 2004
    you will need to make up the wiring loom, i spose i can part with one for $25
    Rob
  15. #15
    VTS5's Avatar
    Jul 2005
    Sth.East\Melb
    Rob
    Without that loom module wouldnt work,so can u make one up?Cause i got no idea.
  16. #16
    Jan 2005
    VIC
    Hi all,
    Does anyone have a wiring diagram or knows which two wires are used for the steering wheel controls for a Series 1 VT Berlina?
    My head unit is the stock Eurovox with a single CD, the part number on the sticker on top says 92050102 and has a single connector on the back.
    I read somewhere it was pins 9 and 16, and different resistance across them do different functions. I connected the controls to both pins with hook up wire to test it and it didn't do squat.
    As I was testing it, I didn't run it through the clock spring, would that have caused it not to work?
    Apparently no resistance is Volume Down, so I tried shorting the pins directly and that did nothing as well, the volume stayed at the same level.
    Thanks,
  1. Help Installing Steering Wheel Controls - VT Berlina Series 1?
    By holdenrules in forum Electrical Wiring / Questions
    Last Post: 24-12-2007, 02:47 PM
  2. Steering wheel controls...
    By shaded_vs in forum Car Audio
    Last Post: 15-12-2007, 09:22 PM
  3. Steering wheel controls
    By garywg in forum Car Audio
    Last Post: 08-05-2007, 10:40 PM
  4. VY Steering Wheel Controls
    By craigmack05 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 12-01-2006, 08:48 AM
  5. VT steering wheel controls.
    By calaisinternational in forum Car Audio
    Last Post: 19-08-2004, 02:23 AM
