Results 1 to 18 of 18
Thread: sub connectors
    VT Executive
    Aug 2006
    Default sub connectors
    hey there i always woundered how others connected speaker wire to sub boxes, i normally unscrew the connectors and slide the wire underneath like the pic.
    V6 VS EXEC S2
    Sep 2005
    drill holes slightly larger than the cable, slide the cable in and silicone the holes.
    VS Acclaim
    Jun 2006
    got the push down terminals so its easy as push down, then jam wire in hole, release.
    is that exposed wire on the right terminal, or is it just my failing eyesight
    Boonz's Avatar
    Boonz is online now the holden mechanic
    green 355 VG ute , silver vx s pac L67
    Jul 2005
    berri, south australia
    they are the way to go the connectors you are using are meant for eye crimp terminals
    VT Executive
    Aug 2006
    Quote Originally Posted by KingBrown
    lol i had to go out and check, it must of been the suns reflection.
    V6 VS EXEC S2
    Sep 2005
    these connectors pictured can be used for bare wire screwed down under the nut (as in the picture), banana plugs pushed straight in and you could use ring terminals if they fit the stud, then screwed down under the nut.
    VS Acclaim S2
    Nov 2005
    Just to be negative, terminal "boards" such as those tend to 'leak' sound. You get a better sound from a method such as that suggested by jds303 with a nice airtight seal and nothing thin and flimsy on the wall of your sub box.
    Tasmaniak's Avatar
    Tasmaniak is offline Not a valid input....
    car
    Apr 2005
    Quote Originally Posted by Brycestro
    On a positive note...if you can hear that difference....I want your ears.
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    I use these below so you don't have to cut a big hole in the box, just drill 2 holes to line up with tabs.
    VY SS
    Aug 2004
    SE Victoria
    Quote Originally Posted by StoneX
    i could see a lot of people snapping the terminals off.
    Tasmaniak's Avatar
    car
    Apr 2005
    My main reason for not using terminals of any form is that they are just another place to cause resistance.
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    Quote Originally Posted by garfa
    Only in dodgy installs where the sub box will move. If your box is secured, there is no issue at all.
    Phreddy's Avatar
    Phreddy is offline Bye SV6 - still love you
    VS-II Statey-8
    Apr 2005
    W-Sydney NSW
    I personally use a "Speakon" connector. (specifically designed for high power PA speaker applications - each plug/socket has four contacts rated at 30A continuous) That's cool too, as it allows both coils of a dual-coil driver to run out the the plug, making your coil wiring options easier - you don't have to pull the driver out of the box to change the config.
    They allow me to quickly remove the sub box connection with one action, and will never allow the wires to touch when not connected. They are a bit spendy though.....
    BTW - Hey Ray!
    New look ASR Website online now!!
    www.asr-audio.com.au
    Interior lighting and audio specialties
    for VT/VX & VY/VZ Commodore / Monaro
    NOW VE DASH LIGHTING CONVERSIONS!!
    PLUS TECH2 DIAGNOSTIC SERVICES
    JBL Car Audio dealer
    V6 VS EXEC S2
    Sep 2005
    speakons are cool, i never thought of using them in car audio tho. they would be great for dual coil drivers.
    im with 12 volt, it might be the occasional pain in the arse to have to disconnect the wiring from the amp if you need to remove the box, but cable straight from amp terminals to woofer terminals is my preference.
  15. #15
    Ute 04 VYIISS 5.7 M6
    Jan 2006
    Newman, WA
    "Speakon" connector?
    Can some one point us in the right direction.
    Where to get some, or at least what do they look like.
  16. #16
    VY SS
    Aug 2004
    SE Victoria
  17. #17
    Tasmaniak's Avatar
    car
    Apr 2005
    Speakons are pretty cool and they do handle EXTREMELY high current flows and yes they are a little spendy but hey. If you want a reliable quick connect and disconnect then you want to be using speakons.
    I have used these several times in car audio and swear by them in PA systems.
    Expect to pay around $30 for one plug and socket if not more.
    BTW... Phreddy, I haven't forgotten about you even though it seems I have Glad to hear your doing ok.
  18. #18
    Phreddy's Avatar
    VS-II Statey-8
    Apr 2005
    W-Sydney NSW
    Hey 12V - never thort I'd see your endorsement of a plug/socket assembly!!
    Yeh, sorry Mate - been pretty bloody flat out as usual, although have a bit more time on my hands now. (heh-heh)
    (you did hear that I got the arse from work, huh?)
    Anyhow, I'm doing OK. I'm gonna give it a shot at going it alone - trying to get a lot of stuff set up ATM, biz registration and ABNs 'n' stuff, supplier accounts, blah-blah.....
    BTW - hey Circle! how's your project coming along?? Have you lined up a climate control module yet? As soon as you do send it on over, I'll "do the bloo"...
    Anyhow, gotta run for now. Cheerz All!
  1. two connectors under dash
    By wangster123 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-11-2006, 07:56 PM
  2. 2 Electrical connectors doing nothing ?
    By f_vos in forum VY Holden Commodore (2002 - 2004)
    Last Post: 12-03-2006, 10:51 PM
  3. VP Calais Loom Connectors - where to buy?!
    By neddo1981 in forum General Discussion
    Last Post: 19-12-2004, 05:31 AM
  4. Where to buy spare loom connectors?!
    By neddo1981 in forum Electrical Wiring / Questions
    Last Post: 16-12-2004, 04:33 PM
  5. QK connectors???
    By Jim_Waddle in forum Car Audio
    Last Post: 01-07-2004, 01:51 PM
