Results 1 to 12 of 12
Thread: 4ch Amp question?
    VN Executive
    Aug 2006
    Default 4ch Amp question?
    Hey just pulled my stereo out of my old VH and put it in my new VN, was just wondering how the channels work on my amp? I have a 4 channel boss amp that runs my splits and 6x9s, the way i did it when i put it all together was: first two channels for front left (channel one) and front right (channel 2) and the same for the back (rear left channel 3 and rear right channel 4). does it matter where the speaker cables go or not? If so where should i put them? I pulled the stereo out of the VH and put it in the VN about a month later so i forgot what it was like on the VH... anyways any input would be sweet thanx.
    SweetWagon's Avatar
    SweetWagon is online now booosted
    VS Berlina Wagon Supercharged & VU SS Ute
    Jan 2006
    Springwood NSW
    Just make sure the correct channel from the H/U, matches up to the correct input on the amp, and that the correct input goes to the correct speaker. fairly straight-forward as most amp's have signage on them to tell whats what. The RCA preouts on the back of the H/U should also be labelled, if not its a matter of trial and error by playing around with the balance and fade.
    VN Executive
    Aug 2006
    yeah it all works just sounds different to before was just wondering if the channels matter, the rca coming into the amp are bridged with another amp for the sub. all the cables from the speakers go into the 4 channel amp.
    SweetWagon's Avatar
    Jan 2006
    Springwood NSW
    Quote Originally Posted by scott's ass
    This doesnt make sense? Are you saying your powering the sub amp with the 4ch amp?? as that would not work.
    semi is offline GOD
    VR exec wagon
    Aug 2005
    WA
    SweetWagon's Avatar
    Jan 2006
    Springwood NSW
    Quote Originally Posted by semi
    no, he means the RCA is split so he can run 2 amps off 1 set of preouts
    I dont know how you interpreted that but then yes that setup would be fine.
    Scott, just make sure the rear RCA channels are the ones being split for the sub
    VN Executive
    Aug 2006
    LOL ok heres what i want to know i have 4 channels, which means on the amp i have 8 terminals + and - for each channel, i have 4 speakers, 2 fron 2 rear... do i put the 2 front ones on the first 2 channels and the 2 back ones on the second 2 channels?
    VY SS
    Aug 2004
    SE Victoria
    the answer is yes by convention that fronts go on the 1st and 2nd channels and the rears on channels 3 and 4. but really each channel is exactly the same so it doesn't matter. the worst thing that could happen is that the balence control on the h/u becomes the control to fade betweek front and rear. just make sure pos is connected to pos on the amp and you don't reverse the polarity of the speakers.
    VN Executive
    Aug 2006
    yeah kool thanx alot man, i got it sorted now... ended up working it out but thanx anyways
    semi is offline GOD
    VR exec wagon
    Aug 2005
    WA
    Quote Originally Posted by vn6pwr
    why split the rears for the sub? I though if anything you would split one set into the 4ch and the other for the sub. Although i think he only has 1 preout anyway
    SweetWagon's Avatar
    Jan 2006
    Springwood NSW
    I'm just assuming he has a full set a preouts ie. FR,FL,RR,RL
    semi is offline GOD
    VR exec wagon
    Aug 2005
    WA
    Thats not a full set of preouts, id say a full set is at least 6
  1. just a question
    By fpr_thunder in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-08-2007, 11:34 AM
  2. Ebay question.... moral question?? lol
    By NORTI in forum The Pub
    Last Post: 03-04-2007, 03:43 PM
  3. V8 or not V8 - that is the question
    By SSV8pilot in forum VE Holden Commodore (2006 - ?)
    Last Post: 21-08-2006, 09:10 AM
  4. VZ ute question
    By Troy711 in forum Car Audio
    Last Post: 28-06-2005, 09:27 PM
