Results 1 to 6 of 6
Thread: Should I port my xbox incorporating sub box?
    VS executive 96
    Jul 2006
    Default Should I port my xbox incorporating sub box?
    Hey, ive been workin on this setup for a while now, trying to get it right and being distracted by little thigns like the HSC and all anyway as u can see in the pictures it encorporates 2 pioneer 10 inch subs facing into the boot and an xbox facign through the fold down seat hole, i have 12volt computer fans on top of the box sucking out and pushing in air around the xbox, each sub is sealed in its own enclosure and the xbox is in its own compartment. i still need to attach side pieces to the box so it looks like a solid wall across the back ( the brackets are there i just got sick of having to unscrew the pieces every time i had to take the box out to change something.The power inverter is located under the drivers seat and there is a 3 foot blue neon wired into the boot light switch. Now that ive finished showing off my work so far i was wondering if anyone could give me some advice as to wether or not it would be advisable to put 2 ports underneath the xbox facing into the cab. would this work considering the subs are facing into the boot and would it achieve any added bass in the cabin? also any other suggestions are welcomed
    Attached Thumbnails Attached Thumbnails Should I port my xbox incorporating sub box?-picture-140.jpg   Should I port my xbox incorporating sub box?-picture-146.jpg
    semi is offline GOD
    VR exec wagon
    Aug 2005
    WA
    huh? is that xbox inside your sub box? With a hole at the back?
    dont port your box, ported boxes need (moreso than sealed) to be designed specifically with the ports matching the sze of the box etc
    VS executive 96
    Jul 2006
    Quote Originally Posted by semi View Post
    Yeah the xbox is built into another box inside the sub box
    semi is offline GOD
    VR exec wagon
    Aug 2005
    WA
    hmm, im not sure if that would affect your SQ, but i suppose it would only be marginal. You wont get better bass from porting that box, and you might ruin your subs.
    if you want better bass, build a box thats better suited to the specs of your subs, as i think that that one isnt
    VS executive 96
    Jul 2006
    no the volume of the box is right for the specifics of the sub. the volume is decieving due to a very irregular shape
    semi is offline GOD
    VR exec wagon
    Aug 2005
    WA
    ok then, not much you can do then really unless maybe you want to make a port from the parcel shelf into the boot, dont think even this will make a big difference
  1. port and polish?
    By harro_VR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-10-2006, 12:33 AM
  2. port and polishing
    By VL Berlina 5speed in forum VL Holden Commodore (1986 - 1988)
    Last Post: 03-08-2006, 09:06 PM
  3. MAF port and polish
    By gen3_350_v8 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 03-10-2005, 07:02 PM
  4. where is the OBDII port on the VR
    By michaelw in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-07-2005, 06:22 PM
  5. FS: 12 Port 202 Head
    By vkberlina in forum Parts And Other Items For Sale
    Last Post: 14-09-2004, 11:40 PM
