Results 1 to 8 of 8
Thread: help with a wiring issue PLEASE(grrrrrr)
    Mountain Guest
    Default help with a wiring issue PLEASE(grrrrrr)
    Hey all,
    I searched the forums and cant seem to find an answer so heres my issue.
    Am installing a pioneer deh-p7550(the older model not this years /last years one) into a vx ss series 1.
    *Have wired the yellow power wire of headunit to the orange/black(not orange/white for some reason) power wire from car.
    *Red accessories wire to yellow accessories wire of car
    *Black to Black/white earth wire (earth is earthed)
    *Blue wire from head unit is a remote wire for amp connection
    *Have checked fuses
    The head unit just wont seem to come on. Do i need to connect an illumination wire? Have i missed something? Very frustrating? Do i need to use the yellow/red constant 12v output for something before the head unit will turn on? Very frustrated!
    Thx in advance for any help
    Andy
    daron's Avatar
    daron is offline wizfiz
    VE SSV
    Mar 2006
    adelaide
    make sure all fuses are ok
    if red wire has llittle plastic tube on it cut it out and buypass it
    the colors you say are corect and it should work
    Mountain Guest
    Quote Originally Posted by daron. View Post
    YES! it does have a little white cble tie around! Could this be the problem?
    also have this
    http://www.service.pioneer-eur.com/peeservice/instrmanuals.nsf/0/3E6188D72B53370AC1256D490041ABB0/$File/CRD3766_DEH-P7500MP.pdf
    could u have a look on page 5. i dont seem to have a "no. 18 orange/white lighting" on the rear of my unit will this matter?
    and soz but one more question should i connect my yellow/red constant to the accessories aswell?
    cheers man much appreciated
    andy
    vp calais
    May 2006
    adelaide
    no you need a constant 12v source and a 12v acc source you cant have one without the other you need 2 power wires
    VY SS
    Aug 2004
    SE Victoria
    well you do know the car need to be turned on to start or ACC before the h/u comes on? just something simple.
    use a dmm to test the power wires aswell.
    VZ SV6
    Jul 2006
    Newcastle
    Something else that's easy to overlook is the small blade fuse at the back of the unit...
    If you're not weird, you're not normal...
    Mountain Guest
    Quote Originally Posted by garfa View Post
    ye lol made sure i tried that
    semi is offline GOD
    VR exec wagon
    Aug 2005
    WA
    we really cant tell you much until you use a multimeter (dmm) to check that theres 12V on all those wires
  1. VN HSV +6 issue
    By And_ROOS in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-12-2007, 03:25 PM
  2. VN HSV +6 issue
    By And_ROOS in forum Electrical Wiring / Questions
    Last Post: 04-12-2007, 11:55 PM
  3. Cause of an issue???
    By boojak87 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-07-2006, 09:42 PM
  4. Shorted out Interier lights.... (grrrrrr)
    By sickvy in forum VY Holden Commodore (2002 - 2004)
    Last Post: 06-11-2005, 08:21 PM
  5. Grrrrrr
    By =Calais v8= in forum General
    Last Post: 27-10-2005, 01:21 PM
