Results 1 to 4 of 4
Thread: kenwood KFC M1628A 3 way 6.5 Speakers
    Jan 2004
    Default kenwood KFC M1628A 3 way 6.5 Speakers
    My son just bought a vr statesman and now has a kenwood system to install.
    The amp, hd unit and speakers are all kenwood.
    I have been given the job of installing it all. The only problem i seem to have is with the front kenwood 3 way 6.5" speakers. The speakers sit in the pod in the door ok but the centre midrange and tweeter sit up a little to high, thus preventing the door trim from being installed correctly. Can you buy different pods, or do i cut away some of the plastic reinforce ribbing on the inside of the door trim behind the speaker grille.
    Also may i ask whether i can leave the current speaker wires in the door, and then just run speaker cable from the amp in the boot to the wiring loom behind the hd unit. the speakers are rated at: peak power 280W, Rated power40W.
    Hope someone can help.
    Kindest Regards
    ssilent11
    V6 VS EXEC S2
    Sep 2005
    you could try cutting the plastic grill completely out of the centre of the pod, or just where the tweeter would protrude. the factory metal mesh grilles (easily sourced if they didn't come with the car) will cover this and hopefully give you a good few extra mm of installation space. failing this, if you have enough depth left in the door, a custom spacer made of mdf rings is another option.
    semi is offline GOD
    VR exec wagon
    Aug 2005
    WA
    if you have nice looking speakers you might want to just leave the covers off (cut em out) completely, rather than replacing
    VY SS
    Aug 2004
    SE Victoria
    you will gain about 5mm from cutting the plastic bars. you can make new pods and cut some of the inner door metal out, but by carefully selecting the right slope to put on the replacement mdf spacers, you can make, it will mean that no metal will need to be cut.
  1. Kenwood 7X10 Speakers VIC
    By blakestone01 in forum Parts And Other Items For Sale
    Last Post: 30-10-2008, 09:38 PM
  2. Replies: 18
    Last Post: 06-01-2008, 07:09 PM
  3. [fs][vic]kenwood 6x9 And 6" Speakers
    By Dragz in forum Parts And Other Items For Sale
    Last Post: 25-09-2007, 03:43 AM
  4. kenwood amp???
    By Troy5L in forum Car Audio
    Last Post: 24-09-2005, 02:14 PM
  5. Kenwood 7x10" Speakers
    By ozute in forum Parts And Other Items For Sale
    Last Post: 20-08-2005, 01:58 PM
