ive got a quick question.
recently my pioneer 6x9 (180w 3 ways)are crackeling when i turn it up. ive got a JVC HU and im not running any amp.
its like the sound it makes when you use a battery on the pos and neg to see which side of the car the wires run down.
any help would be appreciated or tips
cheers james
loose connection near/in the speaker probably. when the cone moves it vibrates the wire around and makes the connection drop out and reconnect, cracking.
seconded for garfas explanation
ahh k cheers.
so a quick fix would be to solder the connections on to the back instead of having cripped connections.
and if it continues is it time for new speakers??
cheers
yep blah blah 10 char
i would test the continuity of the speaker wire and then test the speaker. one of the tinsel leads may be rooted, and then hence replace the wire or replace/repair the speaker
