I was searching the other day and found that the rear wiring for the Amp and rear parcel speakers is in place in my VTII Berlina. Once I had connected the Amp and speakers I still couldnt understand why it would not work. I investigated further and found that the fuse for the Amp has only one connector fitted, so therefore no power is going back down to the Amp to make it operate. Once I removed the fuse cover and other trim pieces and the drivers kick panel, I simply placed a patch wire into the fuse box, from the missing side of the fuse and then connected into the harness connector behind the kickpanel and behold
the amp fired up into gear!!! So if you have the rear harness already fitted in your car for the amp and speakers, then the patch harness will get everything operating!!!
i didn't think there was a amp in the vt
Planned Install for VS
HU:JVC KD-AVX2 Getting Soon
Screen: in dash 7"widescreen
Front Stage:165v2 might have to rethink thanks to defty's advise
Rear:165v1 owned
Sub:33 V2 maybe? have no idea really
Amps: Jaycar 200wrms, 300wrms owend .to be upgraded later plus Fans, maybe Monoblock
Sound Deadening:Dynamat front doors and Boot
Hardrive: new plans hardrive possible a ipod
If You See Any Gd VS Please contact me really want one so install can begin
