Results 1 to 24 of 24
Thread: Wont go loud!
    bognog is offline Banned
    VN
    Mar 2006
    Default Wont go loud!
    Brand new speakers, brand new head unit, can't turn it up barely at all, like i can just hear it over the engine. I've tried running a single speaker straight to the head unit but no difference, what would it be? Can't be the wire throughout the car cause i ran a speaker straight tot he unit with new wire and no diff!!
    Goon's Avatar
    Goon is offline The Future.
    04VYS2/V6. 79VBSL6. 04Mazda3
    Feb 2006
    GC. QLD
    Whats the watts on your speakers?
    max watts the headunit can handle?
    Make sure the headunit isnt stuck on that ATT setting.
    Quote Originally Posted by Jamie-b View Post
    well i think a "headjob" would be better than stroking it?
    VN
    Mar 2006
    The wattage isn't a problem, i've tried 2 head units and 2 sets of speakers.
    However both head units were pioneer using the same plug.
    hakhawk's Avatar
    hakhawk is online now smooth moderator
    BMW E21 320i, E36 318IS coupe
    Jan 2005
    if you tried 2 head units and 2 sets of speakers, its definately something to do with the wiring, bad earth maybe, make sure none of the speakers cables are earthing or shorted against one another.
    daron's Avatar
    daron is offline wizfiz
    VE SSV
    Mar 2006
    adelaide
    out of faze
    change the _ + from one spkr only and swap it over
    see if ya get bass
    VY SS
    Aug 2004
    SE Victoria
    Quote Originally Posted by bognog View Post
    plug?! what exactly do you mean by plug? does the volume change when you increase the volume by much?
    sganro is offline i speak before i think
    yet another VS
    Aug 2005
    NQ
    Quote Originally Posted by garfa View Post
    i think he means the wiring loom
    Tasmaniak's Avatar
    Tasmaniak is offline Not a valid input....
    car
    Apr 2005
    Out Of Phase. check your speaker wiring. Something is a little messed up
    VN
    Mar 2006
    I have swapped neg an pos back an forth on the speakers, makes no difference.
    It has to be a bad earth if i cut the earth wire off the unit an it still works, right?
    Tasmaniak's Avatar
    car
    Apr 2005
    yeah...it means no earth and that the unit is earthing itself through the antenna cable...bear in imind that it only takes ONE speaker to be out of phase and that it can be awfully tricky trying to find which one. Typically if it having trouble earthing itself then when you turn the volume up the unit will switch off.
    VN
    Mar 2006
    Ok well what you just said doesn't clear anything up.
    I tried earthing the unit properly by taking the antenna out and earthing the head unit to metal on the car. No change.
    I've tried connecting a single speaker directly to the head unit and tried swapping the wires back and forth on it. No change.
    The only thing thats unusual to me is there seems to be 2 lumes, so to speak, where one bunch of wires goes towarads the bottom of the car and the other one up into the dash. Off the head unit is 2 wires for each speaker, and those 2 speaker wires are connected to 2 wires coming from the top lume, and then another wire is connected to those 2 wires from the bottom lume.
    I really have no idea what im doing so im not gonna start cutting shit, but yeh it doesn't make much sense to me.
    semi is offline GOD
    VR exec wagon
    Aug 2005
    WA
    There should be a black wire coming out of your head unit. Try screwing a screw (obviously) into a bare metal spot behind your HU and attatching the earth (black) to that rather than the one in your cars loom. Might fix it, might not, but its better anyway.
    To check if its the problem, try to check the voltage drop in the earth by testing across the earth wire and a spot thats bare metal in the car WHILE THE HU IS ON. If the drop is anything significant, say 1V or more, its likely that this is your problem
    If you have one around try to use a multimeter on the voltage setting to test the voltage across the earth spot and the 12V constant. SHould be about 12.4V is the car is off and 14V or a bit more if its running.
    VN
    Mar 2006
    Boonz's Avatar
    Boonz is online now the holden mechanic
    green 355 VG ute , silver vx s pac L67
    Jul 2005
    berri, south australia
    u dont ahve an ipod adaptor attatched to the unit??? my brohter in laws unit wouldnt turn up when the ipod adapter was connected for some reason
  15. #15
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    It's either going to be faulty wiring and/or damaged head unit.
    So take it out of the car, wire it up to a 12v source, hook a speaker up to each channel... Does it work? If not, it's faulty and your wiring probably caused it as the second head unit you tried didn't work either. If it does work, then redo the wiring or get a pro to redo it.
  16. #16
    Tasmaniak's Avatar
    car
    Apr 2005
    Hmmm, nobody has the understanding to come up with a solution??
    Actually, the understanding isn't with us...it's with you. There is various reasons why a headunit won't turn up the volume far....what sort of sound? Does it sound normal and just has no volume? Does it sound a little tinny? Does it sound all distorted?
    Also, a please can generally go a long long way
  17. #17
    semi is offline GOD
    VR exec wagon
    Aug 2005
    WA
    Pfft, stop being a prick. Theres more understanding in this thread than you can poke a stick at, and some good ideas of the causes. You're making it more difficult for yourself by not posting more information after trying stuff
  18. #18
    VN
    Mar 2006
    Quote Originally Posted by semi View Post
    I have said plenty, have a read. Im not being a prick, just direct. Dont be such a pussy.
  19. #19
    VN
    Mar 2006
    Quote Originally Posted by 12Voltking View Post
    It sounds normal till you turn it up it just cracks consistantly.
    What might cause this im thinking. Not enough power to power the speakers? Turning it up too far makes it louder but if it's not getting enough juice it will just distort like that? Hmmm, im just guessing here, i dont understand this stiff im just going by what common sense tells me.
  20. #20
    Tasmaniak's Avatar
    car
    Apr 2005
    then forget your common sense as you have none.
    Sorry, we can'/won't help you here. These guys certainly will
  21. #21
    VN
    Mar 2006
    Well isn't that a surprise, more pussy ass bitches. Grow a dick you old bastard.
  22. #22
    VN
    Mar 2006
    ### it, i had to come back to this thread again.
    Someone calls me a prick and you take offence when i reply to the initial trouble maker? Thank ### you aren't Australian or i'd start thinkin Aus was closing in on the pussy status of Yanks.
  23. #23
    VY SS
    Aug 2004
    SE Victoria
    bognog; pull your head in your talking to a mod.
    go back to your hole and stop making trouble on these forums, no one wants you here.
    stop having a cry because we didn't respond in the manner you have become accustomed to!
    don't bother going to a ford forum or any forum, just piss off.
  24. #24
    Tasmaniak's Avatar
    car
    Apr 2005
    You ****ing moron, before you start making comments about nationality you probably should check things out first. I am Australian you twat.
    Furthermore, you do NOT come on to Australias largest Commodore website and starting ****ing off. You wanted help and we provided it for you. After reading you problem I told you what the issue is. ONE of your speakers is out of phase you moron not all of them. Did you honestly think that reversing the polarity on all speakers would make the issue go away?
    **** off, go back tto the street commodores kids and consider yourself banned.
  1. vx ss LOUD
    By aygee in forum LSx Development and Modification
    Last Post: 07-01-2008, 05:11 PM
  2. deep and loud
    By davidaddison in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-01-2007, 07:16 PM
  3. Loud ******* Rattle!!
    By Keesh in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-12-2006, 05:43 PM
  4. loud rattle now car wont start
    By executor in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-06-2006, 06:24 AM
  5. How loud is your commodore from the outside?
    By Famine in forum Car Audio
    Last Post: 13-01-2006, 10:57 AM
