Someone told me the stock head units in vr/vs are a bastard to remove cos there is a screw in the back of them holding them in or something along those lines? Is this right or were they bulls#$%ing me?
Have a read of this thread.
Complete VN,VP,VR,VS,VQ,VG Headunit Guide [56k warning]
No screws holding at the back (from the ones I have done). The most complicated part is removing the interior trim afaik.
Easiest way is to remove the back window and tow it out with another car.
Ok seriously they are a bastard to remove. Some models do have a little security screw at the back which takes about 30mins to remove after a few beers.
Good luck!
No way, theyre easy as to remove. It might possibly be calais HUs or something that have the screw at the back, but it looks like you have an exec so i doubt it would be there.
My base model Lexcen VN had the screws at the back (facing forward). As far as I know all VN/VP/VR models were the same when standard. My sister in law's VN Exec was also the same but an installer had cut the bracket.
If you have an 8mm flat spanner (no bends) it makes it easier but due to lack of movement it takes time. I didn't have a spanner and it took ages.
Most shops just cut this part of the bracket off rather than try to unscrew it.
Never
$50.00 paid for each answer to a post of mine.
Please note cheques will not be honoured
I've done quite a few vr/vs with stock head units and haven't seen one with the crew in it yet.
Like semi said, i found it pretty easy as well.
ok cool, thanks for that. Gonna get it into my VS this weekend and replace one in my VN while im going![]()
I was talking to a guy at my brother's place today who was rewiring his boat, as it turns out he has been a car stereo installer for eighteen years. He said with VNs and VPs you never know, Exec to the Calais, as some have the screws some don't. No mention of VRs though.
Never
