Results 1 to 12 of 12
Thread: please help ?
    vy executive
    Oct 2006
    Wink please help ?
    i was just wondering where the best place to run my amp cables and rca cables is and where the best place is to put my fuse ?
    and also how do i remove my door trimsto put some splits in ?
    also thanx for the reply from how to remove metal casing cos i now have a dvd screen in my car and its awesome
    sganro is offline i speak before i think
    yet another VS
    Aug 2005
    NQ
    If you are running your cables to the boot, most people run them down the sides of the car under the kick panel strips. if you do it that way, make sure you run the power down one side and the rca down the other so you dont get interference. I just have the power fuse in the engine bay, near the battery.
    There is a thread for taking door trims off, just do a search.
    vy executive
    Oct 2006
    i kinda meant where through the fire wall do i go to get it to the kick panel strips ?
    VS Acclaim
    Jun 2006
    Remember to keep the fuse within 45cm of the battery, the closer the better as there is less unprotected wire.
    There should be a rubber grommet on the left side of the engine as your facing the car. Feed your cable through here. Next to Brake booster on VS but someone else can be more model specific, it should be pretty obvious if you look.
    vy executive
    Oct 2006
    vy executive
    Oct 2006
    VS Acclaim S2
    Nov 2005
    ok, i'm not sure what it's like on the vy, but on the VS, if you have an automatic there's a big old clutch grommet that is unused (oval in shape, has no wires running through it). There is loads of space to run a power wire through there.
    As for your kick panels, once again, i'm not sure on the vy, but on the VS they're simply clipped in place. probably 6 or so clips. wedge a screwdriver under there and try prying it up a bit. you might be able to see them. just use the prying action to release the clips. i broke one or two doing mine, but it still holds on fine. just be careful and you shouldn't have any issues. Let us know how you go. cheers, Bryce.
    Lumps of cheese's Avatar
    Lumps of cheese is offline Who wants chowder?
    MY08.5 VE V8 CALAIS/2010 Hilux SR D4 Dual cab 4x4
    Boulder Crusher Champion! Balloon Park Champion! Action Fish Champion! 501 Darts Champion! Frogger Champion! Jungle Kid Champion!
    Nov 2005
    Warrnambool
    Prise up the kick panel strip with a flat screwdriver, under them are 4 spline headed bolts.
    Just undo them(repeat for back door) and off they'll come!
    vy executive
    Oct 2006
    Talking
    i installed one amp for the splits and they are sick but just like to know how to get the rca cables and amp wire into the boot im thinking i have to take out part of the back seat or is the any other way to get it through there with out taking out the back seat ?
    how do i take out part of the back seat if i have to or where is the alternative if there is one ?
    kowan's Avatar
    kowan is offline Clayton's Commodore
    91 Clayton's Commodore/Toyota Lexcen
    Sep 2005
    Far North QLD
    Not sure about the sedans but if you remove the lower back seat (Removing lower seat: push the front of the seat towards the back of the car and pull upwards) there should be a hole there on both sides to put the cables through
    http://aussiewholesalers.com now closed When I growup I`m gunna buy a real car
    Nov 2005
    Warrnambool
    There are two tabs at the front of the back seat, pull these toward you and the seat part lifts out.
    Then undo two bolts each side to remove the back rests, takes about 2 minutes to remove the back seats!
    vy executive
    Oct 2006
    Talking
    cheers for that. now it should be all too easy.
