Results 1 to 8 of 8
Thread: simply sub wiring
    vhrb30/vxs11v6
    Aug 2006
    canberra
    Default simply sub wiring
    g-day
    ok please keep this simple
    ive got an alpine 1507 and a 12"rockford dvc(dual 4 omh)
    (well two, but trying to get one in the car for space reasons)
    whats the best way to wire it?
    i dont know the tech stuff but have installed simple stereos for years
    without any probs but never played with dvc parrallel or series
    thanx all
    SweetWagon's Avatar
    SweetWagon is offline booosted
    VS Berlina Wagon Supercharged & VU SS Ute
    Jan 2006
    Springwood NSW
    depends how much each sub can take. it will run 225 watts x 2 @ 4ohms or 450 watts x 2 @2ohms. after you find out how much watts rms the each sub takes, you will know if you need to run the amp at 4ohm or 2ohm loads. to run at 2ohm load on a channel you can simply wire the coils in parallel but wiring them at 4ohm is little more tricky.
    VY SS
    Aug 2004
    SE Victoria
    wiring a 4ohm DVC sub to a monoblock is impossible if you want the total impedance to be 4 ohms.
    SweetWagon's Avatar
    Jan 2006
    Springwood NSW
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    It's a 2 channel. If the amp is 2 ohm stable when bridged, wire the coils in parallel (join the +'s and join the -'s, then connect them to the amp bridged). If the amp won't run at 2 ohm when bridged, wire the coils in series (join a + from one side to a - from the other side then connect the spare + and - to the amp bridged.
    SweetWagon's Avatar
    Jan 2006
    Springwood NSW
    Yeah it isnt 2ohm stable when bridged i dont think, but what happens when a second dvc sub is added like in the original post
    VZ SV6
    Jul 2006
    Newcastle
    Here's a link from the JL Audio Web site, it should tell you everything you need to know...
    http://mobile.jlaudio.com/support_pages.php?page_id=161
    Cheers.
    If you're not weird, you're not normal...
    vhrb30/vxs11v6
    Aug 2006
    canberra
    thanks i think
    cant find any info on 2 ohm bridged
    just 2ohms x2 at 450wrms
    the sub is rated at 1000wrms so i think ill give it a shot with 1 sub wired
    in parrallel bridged(900wrmsx1?)at 2ohms this weekend
    the system used to crank(145db)in my old car
    profesionally installed but its been in the garage for a few years
    and felt like blowing my ear drums apart again
    but need boot space so the wiring has to change(sold the old box anyway)
    what would you guys recomend
    thanks all
  1. vx wiring
    By funkman mixatron in forum Car Audio
    Last Post: 27-08-2007, 01:56 AM
  2. wiring
    By 12000 in forum Electrical Wiring / Questions
    Last Post: 28-04-2007, 05:26 AM
  3. vr to vs wiring
    By john hartigan in forum Electrical Wiring / Questions
    Last Post: 14-03-2006, 07:04 PM
  4. Converting standard fog light wiring to driving light wiring
    By tungsten_vx in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-12-2005, 06:30 PM
  5. wiring kit
    By garfa in forum Car Audio
    Last Post: 06-11-2005, 12:05 PM
