hey guys, im installing a set of tweeters and crossovers, now theres no need for anyone to waste their time on this, just if some1 can tell me where the thread is that tells u how to install them it would be good. just copy n paste the thread is kool. thanks
im not sure if there is a thread.. seeing its pretty straight forward. the terminals on the crossover should be labelled eg. "woof+, woof-,tweet+,tweet-, input+, input-". put the speaker wires (from head unit or amp) to "signal+/-", tweeter wires to "tweet+/-" and woofer wires (main speaker) to "woof+/-"
but then you maybe have a crossover with "tweeter attenuation". which allows you to cut eg. 3db from the tweeters if you find them too loud. there will then be another terminal with eg. "-3db" next to the main tweeter terminals. simply move the negative or positive (should be written on crossover which one) tweeter wire to this terminal if desired.
what exact thing do you wan to know? where to run the wires? how to wire? ect...???
