Results 1 to 15 of 15
Thread: Suggestions for my VT sound...need lots of advice!
    Dylan VT's Avatar
    Dylan VT is offline Metal forever
    VT commodore acclaim
    Oct 2006
    Port Macquarie
    Default Suggestions for my VT sound...need lots of advice!
    Hi everyone.
    Eventually I want to have a much better sound coming from my VT than what I currently have. The speakers are stock and sound TERRIBLE for loud heavy metal.
    The CD player is also an alpine 6 stacker in the boot, and instead of just controlling it through remote to turn it on and off, you have to sort of tune it into the radio to get the sound coming out. That may be regular for a lot of you but I've never come across it before. :
    My question is...because the CD player is a good one, should I just replace the speakers? Will that give me a much better sound? Or will it still sound bad because it's going through the tuner for the radio?
    If I'd be better off buying a new head unit and amp and whatever and all that jazz (plus speakers) could I still keep my CD player or should I just sell it to someone and get everything new?
    Thanks guys.
    Wagon_Wheel's Avatar
    Wagon_Wheel is offline Drop A Patch....
    Aug 2005
    Mt Martha, Vic
    WTF?! U tune the stacker through the radio...... GAY! lol never heard of that before, but yeah that could possibly reduce quality a bit.
    What sorta headunit have u got?
    Upgrading the speakers will give u slight improvement, but the speakers wont be fully powered running from the headunit, I definatly suggest running all speakers from an amp.
    You might be able to keep the headunit depending on what it is as i dont know.
    Dylan VT's Avatar
    Oct 2006
    Port Macquarie
    Aside from the CD player in the boot, everything in the cars sound system is stock. The head unit, speakers...everything.
    I'm thinking if I can't keep the CD player I'll just buy a different head unit and take out the stock one, and then get an amp, change out the speakers and be set, but I'd like to keep the CD player if I can.
    I'm just not sure if I'll be able to hook it up without having to tune it through the radio because the quality probably gets reduced there, but I'm not sure.
    VYII SV8
    Aug 2006
    Toowoomba
    The CD stacker must be an FM transmitter type. It will work with any head unit, but it is possible that the quality of sound is not the greatest...I know this is the case with FM transmitters from iPod's and the like. Although from memory, there were some stackers that actually plugged into the radio aerial, rather than actually transmitting the signal.
    In any case, you can upgrade all the other components (including the head unit) without touching the stacker, and it should still work fine. I imagine your first priority should be replacing the front speakers, and maybe the head unit, with better quality items.
    Aug 2005
    Mt Martha, Vic
    Yeah, definatly new headunit, and with the new headunit, it will sound a bit better even with the stock speakers, if its a good quality head unit, but with good speakers hooked up to an amp itll sound sweet.
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    New head unit, keep Alpine stacker as it'll work with any head unit you buy, but use the head unit's internal CD player for most music as it'll be better quality. Then whenever you can upgade the speakers, then amps, sub, etc.
    Dylan VT's Avatar
    Oct 2006
    Port Macquarie
    VR Statesman
    Sep 2006
    If you really want good sound take that stacker and throw it in the bin, changing cd's is easy.
    If money's no issue replace everything, if not the h/u the last thing to replace, the biggest change will come from the quality of your speakers then your amp then your h/u, get $500+ splits, if you really like your music anthing else will sound great at first but after a while all their little flaws will get on your nerves.
    VR Statesman
    Sep 2006
    Also, soft dome tweeters, nothing too harsh like boston or focal
    If you listen to metal all day on harsh tweeters you'll get a headache
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    I like metal and hard rock... I went for Morels, then Dynaudio because they're high end speakers with soft dome tweeters... I found them to be weak sounding... I have now gone for Boston Z6's which sound so much better for everything I listen to.
    Dylan VT's Avatar
    Oct 2006
    Port Macquarie
    Thanks for the advice guys.
    ...and I'm not likely to get a headache. I DO play metal all day and everyday, and I sit infront of this in my loungeroom whilst doing it!
    I think I'm going to put a holt on my car mods. Although the speakrs don't sound great, they still at least play music. I saw Nevermore on the weekend and now I'm going to buy a 7 string!
    Keep the advice coming though guys because I'll need it soon anyway.
    VR Statesman
    Sep 2006
    Nice, i've got a guitar like that except mines a copy and a piece of sh!t (can i write swearwords?)
    Didn't mean metal would give you a headache, just saying tweeter selection would be important for you because of all the high notes.
    off topic a bit but what did you have running your dyn's stone?
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    VT Commodore S2
    Dec 2005
    Wollongong
    I'd start off with a new headunit, some really good splits, withe dynamatted doors, and a single DD 1012 Subby, To power it all you can just use a 2ch amp and a response 800wrms mono
  15. #15
    vt acclaim
    Nov 2006
    just boughta vt and im going down the same track except I have most of the audio gear already.
    alpine 9827 h/u
    pioneer tsc-160r splits
    jaycar 4x130rms amp
    eplison 600rms monblock
    jaycar 12" dvc sud
    just need to sort out some rear fill and all should be sweet.
    later on I will upgrade the h/u init with a double din dvd
  1. VS Sound Advice
    By Maaate in forum Car Audio
    Last Post: 13-08-2006, 02:17 AM
  2. Advice/suggestions for system upgrade
    By vngrunt in forum Car Audio
    Last Post: 18-06-2006, 02:31 AM
  3. Advice and pricing and suggestions on shift kit
    By Ygoford in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-04-2006, 09:35 PM
  4. Need advice - Clunking sound when driving..
    By LaShY in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-12-2005, 05:31 AM
  5. Your advice/suggestions
    By `aCk in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-06-2004, 01:08 AM
