Results 1 to 15 of 15
Thread: head unit wiring troubles need answers asap please
    vn ss
    Oct 2005
    Default head unit wiring troubles need answers asap please
    hey all just installing a new head unit in my statesman and its not working. all the wiring is right the plug has power but when i connect it to the head unit and put the ignition to accesories the head unit does not work. anybody have any ideas?
    cheers
    rohan
    vl commodore s2 rb30e
    Oct 2006
    vn ss
    Oct 2005
    fuse in the back of the head unit is fine. ran it without the fuse and it still did not power up
    Oct 2006
    vn ss
    Oct 2005
    Oct 2006
    SweetWagon's Avatar
    SweetWagon is offline booosted
    VS Berlina Wagon Supercharged & VU SS Ute
    Jan 2006
    Springwood NSW
    ok, pull the plug out the back of the H/U. check that theres power. ie constant and acc on the pins, if theres power on those then its probably the earth and you will need to make your own somewhere.
    vn ss
    Oct 2005
    SweetWagon's Avatar
    Jan 2006
    Springwood NSW
    you can also test to see if the unit works at all by twisting the constant and acc wire together and go around to your battery and touch the wires on your battery. ie, constant+acc wires to (+), earth to (-) on the battery. it should power up.
    SweetWagon's Avatar
    Jan 2006
    Springwood NSW
    Quote Originally Posted by vq 304 View Post
    ill be back goin to check. the constant and acc are what colours?
    wiring diagram found here:
    VK-VZ Stereo wiring colours.
    there wires should be:
    Accesories - Yellow
    Constant - Orange/White
    but you should always check them with a test light/multimeter
    vn ss
    Oct 2005
    i have power from the battery line and the power line but when i put the test light on the negative pin nothing happened. does this mean i need to run a new earth?
    SweetWagon's Avatar
    Jan 2006
    Springwood NSW
    did you test you have power on the acc wire when you put the key to acc? The earth wont have power because it is only used to complete the circuit. you should be able to use the one there if the previous unit was working else run your own but test that the new earth works.
    vn ss
    Oct 2005
    vn ss
    Oct 2005
    well ran the new earth and all works fine thanks for the help vn6pwr. rep points are on there way.
  15. #15
    SweetWagon's Avatar
    Jan 2006
    Springwood NSW
    no problems, glad i could help
  1. Replies: 10
    Last Post: 25-11-2007, 10:33 PM
  2. Wiring a new head unit?
    By cducktv in forum Car Audio
    Last Post: 13-10-2007, 10:08 PM
  3. Wiring DVD head unit and laws
    By revin rosco in forum Car Audio
    Last Post: 28-07-2006, 11:37 PM
  4. Wiring for pioneer head unit
    By Street Lethal in forum Electrical Wiring / Questions
    Last Post: 11-06-2006, 12:43 AM
  5. head unit troubles
    By scolari in forum Car Audio
    Last Post: 22-01-2006, 09:52 PM
