How do you get the grills off for the front and rear speakers, do they just pull off because they are clipped in or are there screws etc or do I need to take the door panels off?
If you are trying to remove the stock speakers then you will need to take the skin off.
Can't remember how the grills are attached.
So take the whole door trim off? any guides available?
It's pretty straight forward but there is a guide here somewhere, just run a search for door trim removal and you'll find it.
I removed mine without taking off the trim by using a right angled screwdriver.
