Results 1 to 7 of 7
Thread: Electric Aerial
    98 VT Supercharged
    Mar 2006
    Ipswich Qld
    Default Electric Aerial
    If I replace my stock head unit using plugs will I still have my auto aerial?
    Tasmaniak's Avatar
    Tasmaniak is offline Not a valid input....
    car
    Apr 2005
    what sort of plugs are you talking about? Butt plugs?
    98 VT Supercharged
    Mar 2006
    Ipswich Qld
    The wiring plugs from autobarn so i can just plug my stereo in the vt wiring thingy
    Tasmaniak's Avatar
    car
    Apr 2005
    yes on the provision that the new deck has the antenna/amplifier remote trigger. Chances are though it will be up all the time when the HU is on...even if your listening to cds.
    wrx884's Avatar
    wrx884 is offline WA's ASR Rep
    VT Commodore Exec/5L VP Calais
    Mar 2006
    i wanna install an electric aerial replacing my manual 1 2 stop clowns gettin the idea of breaking aerials is fun lol ive got an aftermarket head deck and it has the remote wiring 4 my amps. can i connect it up so the aerial only comes on wen i turn the radio on?? if so how??
    VP Calais '93
    Mar 2006
    SA- NE BURBS
    You could wire it so that it only goes up when the ignition is on.... but then its up even if your radio/ cds etc are turned off...... I believe it's just a matter of hooking the power antenna trigger to the right ignition wire.... i didnt wire mine like this so check with others on here..... its been a while since my last install
    wtb: rockford fosgate sub rfp 3412
    wrx884's Avatar
    Mar 2006
    yer ive been reading a fair few thread but most ppl seem 2 b doin it 2 VN's r they pretty much the same principle as a VT? would it work if i ran another wire from the remote wire from the Head deck and put a switch in between and turn it on wen eva the radios on?? would still like it 2 work only wen the radio turns on it goes up and wen its off it goes down but ne more info would b great?
  1. Electric Aerial
    By numchuker in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-04-2007, 08:36 PM
  2. electric aerial
    By knight97 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 24-03-2007, 02:49 PM
  3. electric aerial
    By Pete284 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-05-2006, 07:33 PM
  4. electric aerial
    By Haze in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-04-2006, 10:42 PM
  5. electric aerial
    By fu2 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-12-2005, 09:17 PM
