Results 1 to 4 of 4
Thread: replacing head unit
    vt acclaim
    Nov 2006
    Default replacing head unit
    to remove the old headunit, I remove it by the 4 small holes in the front, got that bit covered. The question is do I have to pull the dash apart to fit an aftermarket head unit and one of the pocket things. If I do is there a link or can someone explain the easiest way of doing it so I dont break anything.
    Thanks guys
    daron's Avatar
    daron is offline wizfiz
    VE SSV
    Mar 2006
    adelaide
    you dont need too remove anything
    pull out old radio
    wire up new radio
    place can in hole
    poprivit can to sides
    slide in new radio
    trim little side plastic bits off pocket and push it in
    your finished
    VX EQUIP S2
    Nov 2006
    im removing my head unit, and having troubles figuring out the 4 hole business and advice on tools needed would be much appreciated....plz help thanks
    daron's Avatar
    VE SSV
    Mar 2006
    adelaide
    coat hanger wire or smaller or 4 small drill bits or anything that will fit in there
    push them in and spread apaprt left-right and it will pull out
  1. Replacing Head Gaskets
    By sparkymac in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-12-2006, 09:19 AM
  2. Replacing speedo unit in VNs1
    By savage1987 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-06-2006, 09:34 PM
  3. replacing front indicator unit
    By hold-on in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-12-2005, 06:13 PM
  4. Replacing Head Unit
    By holdensupporter2005 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 23-10-2005, 10:54 PM
  5. Which head unit?
    By Famine in forum Car Audio
    Last Post: 02-10-2005, 05:02 PM
