Results 1 to 4 of 4
Thread: VS/Lexcen central locking not working after cd install
    vs/lexcent4
    Dec 2006
    Default VS/Lexcen central locking not working after cd install
    Has anyone had a problem with central locking not working after a cd unit has been installed to a T4 lexcen(aka VS comm), thankfully I did not do the install myself, I am thinking that they have used the wrong wires and maybe sending wrong signal to BCM.
    Does the BCM need any signal as before the radio would have to be powered from or checked by BCM for correct radio pin installed. How does this normally work when non-gen unit fitted?
    VL, VH V8 wag, Zook Vitara.
    Apr 2005
    Ardlethan, NSW
    the only way i see this making sense is the car shares the fuse for the radio and central locking, but if the radio works fine the locking should...
    Need some parts for my VH 253:
    Green standard steering wheel...Green lower B-pillar covers.
    Green sunglasses holder/lower dash bits...Air-con and assorted engine bay parts.
    PM with any info.
    JJ's VR's Avatar
    JJ's VR is offline VRHLDN
    VR 3.8lt Supercharged 163.8kW & VS sII HSV Senator
    May 2006
    Did you have any front speakers (inside front door pods) installed? If so, perhaps check wiring loom between chassis and front doors. They might have accidently pinched/cut the central locking wires, these run through the rubber boot between chassis and front (&rear) doors. I wouldn't worry about the BCM just yet, highly unlikely.
    96 VS 3.8
    Dec 2006
    Quote Originally Posted by anthony0281 View Post
    Has anyone had a problem with central locking not working after a cd unit has been installed to a T4 lexcen(aka VS comm), ?
    i own a 1996 vs toyota lexcen and there is a small computer above the fuse bit just under to the right of the stearing rod check the connections if they are conected good and peoper find another moduel its held up by 2 small screws this moduel controlles few parts of the engine and all lights guages locks and very rarely suspention
  1. Central locking and pwr windows not working?
    By Malus in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-03-2007, 11:22 PM
  2. central locking
    By vlpurpy in forum VL Holden Commodore (1986 - 1988)
    Last Post: 05-03-2007, 02:55 PM
  3. Central Locking not working
    By RedGoesFaster97VS in forum Electrical Wiring / Questions
    Last Post: 14-08-2006, 09:03 PM
  4. VN - Central locking not working
    By enrico in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-01-2006, 02:48 PM
  5. oh no, not working - powerwindows, central locking
    By jessedevery1 in forum Electrical Wiring / Questions
    Last Post: 26-06-2004, 01:23 AM
