Just wondering if anyone has had any problems installing amp cable past all the computer controls for a VY? THey are at the left side of the footwell on the passengers side of the car.
I ran my amp cable right past them installed all the stereo gear started the car it started like a heap of shit and then when ever i pushed the throttle pedal in it nearly stalled. Unplug the amp and its running fine. Has anyone had this before? and how do you fix it? Im not moving the cable to the otherside as the main wiring harness for the car is on the drivers side.
Cheers.
well then i guess your car will "run like a heap of shit".
just run it of the other side. if the cable is too short, then dont be cheap just buy some more and do it properly.
cant run it on the otherside, car wiring harness there. its fine now dont know what its problem was
the power is fine to run with the harness. shouldn't be causing a problem in the 1st place tho...
if the battery was disconnected while fitting the stereo the PCM may have needed to do an idle relearn, some LS1's do this.
Rob
Or the battery wasnt disconnected and he was left with a poor charge until the altenator fixed things? ? ? Strange.
wtb: rockford fosgate sub rfp 3412
went to holden yesterday for some other issues and they couldnt find any problems with the cars computer so i dunno
Doc Bob just took th words straight out of my mouth....theres no fault here to be worried about.
