Well its got me beat. I have been searching for a Audio wiring diagram for a VY with a Bluapunkt 6 Disc.
I have put many variables in my search, But nothing. for 2 hrs
I have looked at the sticky and it gives me a rough idea.
I am trying not to cut any of the cars factory harness, I know I need the Aerpro 7201 plug for the harnes. and areial adapter
But this plug dosen't have a Mute wire, The steering wheel control wire, Amp remote wire. Does anyone know of a link to the cars factory harness diagram please. so i can trace the wire colour for these and splice into them. if I have too.
I am sure they run off the top plug in the Blaupunkt cradle
Swinghammer....there should actually be a sticker on top of the unit itself showing which pin is which and then you trace it back to the colour.
Thanks for that.![]()
I only quickly took the head unit out to see if the Aerpro 7201 adaptor would fit the connecter in the cage.
I noticed there is another plug in the cage, maybe this plug is for AMP , Steering, Mute and so forth.
I will take a look in the morning at the sticker
