Results 1 to 7 of 7
Thread: Help!!!
    VStooDie4's Avatar
    VStooDie4 is offline Rubber should be punished
    VQ 5l ST88TO & VT exec
    Nov 2005
    Muswellbrook
    Default Help!!!
    I just bought a sub and amp today, but cant get them to work.
    I have a clarion db346mp h/u with 2 sets of pre outs, and im trying to conect to a mono audioline amp AL8001ZX. For some reason the pwer on my amp only comes on when i have a pre-out hooked up.
    And would a 2ch wiring kit work on a mono amp??
    Take it easy, just go slow, kinda like a ricer, just try and make less noise.
    I do have respect for road rules AND im a P-plater. Ok im lying...but i am a P-plater.
    VStooDie4's Avatar
    Nov 2005
    Muswellbrook
    I probably didnt make much sense before.
    The amp i have is a monoblock, but the guy gave me 2ch wiring kit. Is there a certain type of wire just for mono blocks??
    VE II SV6 Sportwagon
    Sep 2005
    nah mate same stuff for 1 or 2chan, wat gauge wiring is it?
    have u connected up tha remote starter wire from tha amp (duno its proper name), but tha real thin wire from amp in2 headunit along with tha RCAs, cause that wire will tell tha amp 2 turn on wen tha headunit is turned on
    VStooDie4's Avatar
    Nov 2005
    Muswellbrook
    Yeah i hooked the remote cable to the power cable on the headunit, not sure if thats right?
    Sep 2005
    iv got myne wired to an accecories wire, ie: for tha elec antenna and so forth, but without looking at tha bak of ur headunit hard 2 say wat urs is meant 2 go 2.
    so ur amp doesnt turn on wen u turn ur headunit on?
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    Make sure your ground is good... To the chassis somewhere and paint sanded away.
    The fault of the amp only turning on when RCA's are connected is because the RCA's act as a ground.
    94 VR Commodore Executive
    Dec 2006
    there is a little blue cable that came with the amp that has onyl one wire in it
    this is called the memory trigger
    connect it to the active terminal on the cigarette lighter for an easy installation
