Howdy.
Got some VDO Dayton Splits For an absolute Bargain today so i convinced my friend to buy them for his VS commodore.
Ive successfully mounted the woofers in the stock locations but have come across some troubles with the tweeters.
Im just using the Woofer wire going into the INput of the crossover, From there it continues to the woofer.
I have a few questions from here.
How do i get the dash demister panel off to have access to the tweeter?
Now if i can get easy access to the tweeter, What Color wires are they (im guessing they end behind the door????) so i can use those exsisting wires to hook up the new tweeter + hook it up to the X-Over.
Also the right hand woofer (Stock one, and the new one we put in) Will only work when it gets over a certain volume.
The right hand tweeter will still work, but the woofer will kick in when the volume on the HU gets to Say 12 (its a mid range 3 year old JVC)
I read the headunit installation guide and i really do not want to do that.
My mate thought this would be a simple process and if i take any more of his car apart he will get very annoyed....
Is there an easy way out of this?
Like i said the woofers are in already but i need to get these tweeters in too, And the right hand woofer problem is also a doozy.
And yes i did do a search.
Cheers for any help.
((How do i get the dash demister panel off to have access to the tweeter?
Now if i can get easy access to the tweeter,))
there are 2 small philips screws hidden in the dash demister bit if you look down with a small mirror you will see them
i know because i have my hole dash out, stupit fan die,
