Results 1 to 8 of 8
Thread: Power Connection For amp
    Oct 2004
    Default Power Connection For amp
    Hey guys, i was just wondering if anyone had any tips for installing the power lead for the amp.
    I have a 1997 auto VS commodore
    Any suggestions are welcome
    DJ Majah's Avatar
    DJ Majah is offline Electro doof doof styleé
    VSII cruiser
    Jan 2004
    Brisbane - Ipswich
    Autos are easy because there is a hole in the firewall for the clutch cable.
    1. Start at the bonnet end, find the unused grommet right under the brake booster, it will come out the other side to the left of the steering wheel down pretty low behind the flip down fuse cover. Then start pulling it through.
    2. Remove the plasticy/rubberish lining around the bottom of the door that holds in the carpet and run it under there.
    3. When you get to the back seat, you can leave it in (or if you find it easy to take out, go for it. Otherwise leave it). Try to take off the lining up the side of the seat a fair way, you can then go in from the boot and take off the carpet up the side at the back and you should see some light. Stick a big screwdriver or something through the hole, go back to the seat and sticky tape your cable to it, then pull it through.
    Its much easier if you've got a mate to help you too!
    Queensland - The Cruising State
    2_SeeK_U's Avatar
    2_SeeK_U is offline Wheels on the bus go round and round...
    1997 VS Commodore II
    Oct 2003
    Wollongong
    Just remember to run your power cable on the opposite side of the car otherwise you'll get some interference. I had to run my power cable down the passengers side. There was an unused gromit that lead right under the glove box, so l used that and then fed the cable down the side under the carpet to the back seats and into my boot. If you like l can take photos 2morrow, l would now but its dark, plus its raining!!
    ::```cCcc`````````````````````````````::
    Oct 2004
    fourstar82's Avatar
    fourstar82 is offline Graphic Designer
    VYII 25th Anniversary
    Jan 2004
    Templestowe, Melbourne
    Sorry to restart this thread, but I'm having trouble finding the unused grommet right under the brake booster. A photo would be much appreciated. And yes I am up late cause i been down there for the last hour or so trying to work it out, oh and now the car won't start... gggrrr
    Back in the hope things have settled down...
    fourstar82's Avatar
    Jan 2004
    fourstar82's Avatar
    Jan 2004
    right, worked it out. Now the problem I have is that i have no idea what to connect the earth cable to in the boot
    cohn's Avatar
    cohn is offline VN28CN
    VN Calais Turbo
    Nov 2004
    Penrith
    you can run a cable back to the negative battery terminal for the best earth or you can just bolt it to your car body. it is better to fine a factory earth and use that point but you can get away with any body bolt aslong as you clean the surface up a bit with some abrasive paper or similar and put the earth there.
    the earth can basically go anywhere aslong as you have a good contacted and its not a positive wire.
    hope this helps.
    Cheers.
  1. dfi to coil connection?
    By Tong in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-03-2007, 06:24 PM
  2. wire connection
    By dijm8 in forum Electrical Wiring / Questions
    Last Post: 09-03-2007, 11:14 PM
  3. Amp connection
    By myhsv in forum Car Audio
    Last Post: 06-09-2006, 08:18 PM
  4. Amp connection stock H/U VX
    By Decksta in forum Car Audio
    Last Post: 29-06-2006, 03:30 PM
  5. VT ECU connection to laptop
    By Chester in forum Electrical Wiring / Questions
    Last Post: 28-09-2005, 08:56 PM
