Results 1 to 4 of 4
Thread: amp wiring
    vs executive
    Jul 2006
    Default amp wiring
    G'day everyone.
    I have a vs sedan.
    I'm planning on putting an amp in the back underneath the parcel shelf. Just wondering what the best way of wiring it up would be. Where abouts do you put the power cable through from the battery to inside the car, and if i was to eventually out in another amp, would i need two cables going from the battery??
    Cheers.
    SweetWagon's Avatar
    SweetWagon is offline booosted
    VS Berlina Wagon Supercharged & VU SS Ute
    Jan 2006
    Springwood NSW
    in regards to where to run the cable through, most people use the un-used clutch grommet on an auto or I used a grommet next to the brake booster. make sure you seal it back up and then you can simply run it down the drivers side of the car under the kick/sill panel. if you will be getting another amp, use a larger gauge cable than what you need going to a distrobution block, from their 2 or more smaller guage wire can be used
    2000 VT S-Pack II
    Dec 2009
    SE Queensland
    Quote Originally Posted by SweetWagon View Post
    Diggin up an old thread sorry lol. How do you get the wires from the back of the head unit and get them down the side of the side skirts and then into the boot? how does the wiring in the that side skirt make its way to the boot? trying to wire my sub/amp combo atm
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    If you're talking about the RCAs and remote wire, you run them up under the dash or under the front floor carpet across to the sill, then along the edge of the sill, under the rear seat, up through the hole behind the rear seat back rests that feeds through near the strut towers... Done.
    You do need to pull out your rear seat and backrests and the plastic sill trims and kick panel cover... On the left side of the car.
    The power from the engine bay goes down the right side of the car in the same way.
  1. vx wiring
    By funkman mixatron in forum Car Audio
    Last Post: 27-08-2007, 01:56 AM
  2. VR BCM wiring
    By alpine_exdemo_vr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-03-2006, 08:59 PM
  3. VH wiring
    By Jimboss in forum Car Audio
    Last Post: 22-01-2006, 12:38 AM
  4. Converting standard fog light wiring to driving light wiring
    By tungsten_vx in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-12-2005, 06:30 PM
  5. vt cd wiring
    By oldmate007 in forum Car Audio
    Last Post: 04-01-2005, 11:11 PM
