Results 1 to 15 of 15
Thread: Stereo and Airbag Help
    HSV 2004 GTO
    Nov 2006
    Default Stereo and Airbag Help
    Got a quick question for you guys
    Doing the complete install on the weekend.
    Question is: when I have the rear seat removed in the GTO for the install, I have heard that I must be very careful not to set the airbags off. can this happen with the airbags with the seat out?
    And if so, How can I test the stereo system is working before I put all the seats and trim back in without me setting off the airbags?
    I know to have the battery disconnected during install.But what about testing
    help would be very much appreciated please
    VK BROCK Group "A"
    Dec 2006
    KENMORE QUEENSLAND
    Quote Originally Posted by Swinghammer View Post
    As you are aware the airbags are controlled by an electrical pulse which triggers the airbags.
    As for you app I only assume that it has FRONT and PASSANGER AIRBAGS only... unless you remove the bumper as smash they YELLOW triggers I highly doubt you will trigger the airbags.
    With the Volvo, Mercedes etc that have side curtain airbags this can be an issue when installing, though since you would not have these ... there is nothing to worry about
    My only advise is dont touch the SRS circuits... as a pulse or short will trigger the airbags.
    Make sure you have fuses installed proir to testing... and you should be fine.
    Alot of installers will tell wives tales to stop people installing ... and in your case I think that this is the situation.
    Subscribe Here for our monthly Specials
    ALPINE PIONEER Rockford Fosgate Scosche EFX JVC SONY INFINITY
    HSV 2004 GTO
    Nov 2006
    Thanks for the help.
    I have driver and passenger airbags and side airbags too in the HSV GTO Coupe.
    Maybe I saw it on a international forum about removing the back seat in the GTO Coupe an setting off the airbags
    VK BROCK Group "A"
    Dec 2006
    KENMORE QUEENSLAND
    We have not done the GTO before.
    If you know where the sensor for the side airbags you will just need to avoid it.... say it will behind the trim in the "A" pillar.... might be that some people have taken the rear seat out of the car and forced it out through the door and hit or damaged the yellow sensor for the airbag...... so watch the part of the trim on the same side as the striker plate..
    So what did you end up with??
    HSV 2004 GTO
    Nov 2006
    Thanks.
    I will have to to remove the rear side panels too, which is a bit of a worry.
    I ended up with just a average system because I am saving some money for a Twin Turbo setup
    Kenwood DDX 6039 HU
    Kenwood KNA-430 SAT NAV
    Pac SWI-ALP Revision 1.416( Not available in Aussie) and is wired ,not IR
    Alpine SPR-17LS Front
    Alpine SPR-17LP Rear shelf
    About 8km of cable
    Jaycar AA-0426 AMP . Got talked into it today when picked up cable today
    Alpine 12" Sub ( Old one I had sitting aroud and a Pioneer AMP for it.
    And a reverse camera
    I know it's just a average system, But I am really looking forward to some Turbo's
    VK BROCK Group "A"
    Dec 2006
    KENMORE QUEENSLAND
    Does the KENWOOD need the Pulse Unit?? from our experience the ALPINE units were the only one that needed the Pulse trigger.
    Though we dont stock Kenwood anymore due to ...........
    lieos is offline what ford i didnt see it
    Aug 2005
    sydney
    we had a come come into our work it had an aftermarket dvd and dvd stacker and sum1 wired sumfing or rather wrong and when they closed the doors of there car the airbags were triggered
    Tasmaniak's Avatar
    Tasmaniak is offline Not a valid input....
    car
    Apr 2005
    The GTO does have side airbags. From memory it was an option in the Monaro.
    jules's Avatar
    jules is offline we like the bun
    pimpin
    Dec 2003
    Quote Originally Posted by Car Audio Factory Outlet View Post
    untrue i'd say.
    the wires trace back into the c o c k pit. if you short them out you can trigger the bags.
    Aug 2005
    sydney
    when you install electrical in a car with airbags it is always smart to disconnect the battery and from memory let the car sit for 10mins before you touch it because a slight pulse may set ur airbags off.
    HSV 2004 GTO
    Nov 2006
    Thanks for some help guys
    Yes Battery always disconnected when installing.
    The main Question is if I test the system with the rear seat and front and rear side panels removed, will this set the side airbags?
    I am not touching any of the airbag wiring
    VY Series 2 SS
    Oct 2006
    brisbane
    Dont worry about the airbags as long as you have the battery disconnected and dont hit the sensors hard i.e. hammer or something heavy youll be fine - slight bumps dont do shit. In my VY the sensors are at the bottom of the pillar between the front and rear doors youll see it when you take the trim off. Dont know where they are on front side pillars but i imagine they will be just behind the trim also.
    You wont set them off while testing, tested mine nothing happed, the only way youll set them off is if you purposely hit them with something - youll be fine.
    Tasmaniak's Avatar
    car
    Apr 2005
    If your not touching the wiring then you have absolutly nothing to worry about.
    HSV 2004 GTO
    Nov 2006
    Thanks Guy's fot the reply
    Got all the interior out now. Just trying to find a place to put the AMP power wire through the firewall..
    Searched for an hour but can't find the gromet people are talking about. Somewhere near the Brake booster I think?
    Trying for a drivers side power and a passenger side for the Audio.
    The only place I think to put the Amp power is in the bonnet cable gromet.
    Any know of another place for power wire on drivers side please?
    on the drivers side behind the rear quater panel, there is a small box with it a thing that stuck on it looks like a tweeter , the box is about the size of a packet of smokes. What would this be?
    My car is a HSV GTO Coupe
  15. #15
    VK BROCK Group "A"
    Dec 2006
    KENMORE QUEENSLAND
    on both sides or just the one??
    usually the crush box is only the size of a relay... and a bright colour such as YELLOW OR ORANGE...
  1. No airbag?
    By VRdrift in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-05-2008, 11:10 AM
  2. Airbag cover
    By <RaBBiT> in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-01-2008, 01:11 AM
  3. do i have an airbag?
    By axemurderer101 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-12-2007, 03:52 PM
  4. Airbag re-programming (self)
    By tariqzvt in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-03-2006, 10:00 PM
