can any1 help me with fitting roof mounted screens in my VN wagon?? i wanted to look at how it was done b4 attacking the job myself. any help b much appreciated.
CHEERS, ROCK ON!![]()
CAR: VT Commodore Sedan audio car - SOURCE: 7" double DIN DVD/GPS - AMP: Pioneer monoblock / Pioneer 4 ch. - SUB: Kenwood DB+ 12" in 22lt slot ported box - REARS: Kicker RS60.2 splits - FRONTS: Kenwood KFC-S702P splits - MISC: Custom fiberglass iPhone4 dock moulded in center console, White / red LED cluster and dash lighting, SAAS Vortex drivers seat
where are you mounting it? if you mount it in the stock light spot you can use the ground and stuff you the stock light and change the light switch on the doors to an on/off switch on your dash and then you save a few hours of getting wires in the roof.
Hope this helped a bit
thanx phat com, but i more or less wanted to know how it was mounted to the headlining, coz its only that flimsy cardboard crap. i was thinking bout puting a 9" screen just infront of the rearveiw mirror in the front. any suggestions?? thanx.
if you wanna mount it 2 the headlining u have 2 reinforce it and i made a bracket outta tin, thats what i did when i did mine.
did u actually fix the tin to the roof, or just the headlining? is this the same technique as used by installers?
