Results 1 to 9 of 9
Thread: 2004 GTO Aerial probs
    HSV 2004 GTO
    Nov 2006
    Default 2004 GTO Aerial probs
    Got a question for you guys please.
    I have taken out the Factory Blaupunkt 6 Disc unit in my GTO and replaced it with a Kenwood DDX6039 HU.
    The Blaupunkt headunit had 2 Aerial Coaxial cable going into it.
    Now during the install I traced the 2 aerial cables and 1 cable goes to the Aerial which is amalgamated into the rear window Demister lines. The other coaxial cable goes into a small box on the rear shelf which says on top of it ( Aerial Amplifier.
    I connected the Kenwood to the the cable that goes to the rear window.
    My radio reception is ok in the city, but I lose reception when I veture out of the city.
    Should I somehow connect to the other Coaxial cable as well?
    Problem is the Kenwood unit has only 1 coaxial plug like most Head units do, The Kenwood has a seperate wire for Antenna amp , but it is just a single thin wire and not a coaxial cable.
    Any ideas please?
    My car doesn't have a external aerial as such. The only aerial it has is intergrated into the rear window glass
    VK BROCK Group "A"
    Dec 2006
    KENMORE QUEENSLAND
    Quote Originally Posted by Swinghammer View Post
    Any ideas please?
    Say it would be one for Phreddy!
    Though.. firstly the wire coming from the HU would be the Power Aerial Wire?? YES/NO not the aerial amp wire?
    I would "T" the aerial connection at the HU end and run your OEM Coxials lead to it, should solve the problem. But from your description it sounds like that one lead from the amplifier goes to the HU and amplifies the signal coming from the flate aerial... which mean the HU PCB is doing the mixing etc.. so in that case may not work by "T" ing the cable.
    May be a mod for PHREDDY!!
    Subscribe Here for our monthly Specials
    ALPINE PIONEER Rockford Fosgate Scosche EFX JVC SONY INFINITY
    HSV 2004 GTO
    Nov 2006
    Here is a pic of the factory Blapunkt HU,
    It shows the 2 Aerial sockets.
    1 goes to the intergrated anttena in the rear window and the second goes to a small black box on the rear shelf, Which is about the size of a box of matches. '
    The box has a sticker on top of it saying Antenna Amp, I can't remember if the second wire continues from the box to the intergrated rear window antenna.
    Looks like I will be pulling the rear shelf again to see if the wire continues.
    Attached Thumbnails Attached Thumbnails 2004 GTO Aerial probs-aerial-connections.jpg
    Doctor Bob's Avatar
    Doctor Bob is offline Grandpa
    VT V6 Exec & VN V6 Exec
    May 2004
    Mornington Peninsula
    the coax from the amplifier is called the diversity antenna, the original h/u blends the signals to provide better reception, im not sure if joining them will work, try using the diversity antenna & see what happens.
    Rob
    HSV 2004 GTO
    Nov 2006
    Thaks Doc Bob.
    Are you saying disconnect the antenna wire from the socket and plug it into the other socket and see what happens?
    Doctor Bob's Avatar
    May 2004
    yeah try that & see what happens, the primary antenna should provide the strongest signal though.
    Rob
    VK BROCK Group "A"
    Dec 2006
    KENMORE QUEENSLAND
    Quote Originally Posted by Doctor Bob View Post
    Rob
    Nice -- Rob.. did not know that these had a diversity aerial... that explains alot!
    HSV 2004 GTO
    Nov 2006
    Thanks Doc bob.
    I will do it tomorrow and see what the outcome is.
    I can't remember if the wire continues from the Antenna amp box on the rear shelf to the antenna in the window. Do know if it continues please?
    I am getting old and my memory is failing
    Doctor Bob's Avatar
    May 2004
    yes i think it should continue up & connect to the glass
  1. SAT Nav for 2004 GTO
    By Swinghammer in forum Car Audio
    Last Post: 18-11-2006, 01:40 PM
  2. my new 2004 VY Wagon
    By Wagone in forum VY - VZ - WK - WL - V2
    Last Post: 10-09-2006, 12:39 AM
  3. Electric aerial probs?
    By Kall911 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-08-2005, 12:48 PM
  4. From 1991 and into 2004
    By Spiral in forum VY Holden Commodore (2002 - 2004)
    Last Post: 05-10-2004, 08:34 PM
  5. Living In 2004
    By dragrat in forum Jokes/Humour
    Last Post: 15-04-2004, 10:32 PM
