Results 1 to 15 of 15
Thread: Ported Application
    Black VZ SV6
    Dec 2005
    Default Ported Application
    I currently have 2 pioneer 12" ts-306's in a sealed box running with a 500rms monoblock. I have been considering getting a ported box for these subs considering i listen to mainly hiphop & rnb (Apperently ported is suited better with this type of music). Has anyone used these subs ported? If so how did they go?
    Also what would be the best way to face the subs?
    With my sealed box i had them faced forward thru the fold down part of the rear seat, i turned them backwards and it made a hell of a difference. Would it be possible to have the subs facing forward and the ports facing backwards?
    Drive it
    Like ya stole it!
    VK BROCK Group "A"
    Dec 2006
    KENMORE QUEENSLAND
    Quote Originally Posted by jaisvz View Post
    Pioneer dont recommend a PORTED Box for these... and honestly they sound better in a seal box of 1.25cuft is the optimum for these subs.
    Rec. Sealed Box Dims: 0.85 - 1.75 cu. ft.
    Rec. Ported Box Dims: not recommended
    Free Air Usage: not recommended
    Sensitivity: 89 dB
    Frequency Response: 18-500 Hz
    Subscribe Here for our monthly Specials
    ALPINE PIONEER Rockford Fosgate Scosche EFX JVC SONY INFINITY
    VS Acclaim
    Jun 2006
    Gotta disagree with CAFO, these subs do go well in a ported enclosure. If i recall correctly the EBP is ~70 indicating suited to either ported or sealed. Your f3 (how low the sub can play) will be considerably lower ie deeper bass - the trade off is higher group delay (how laggy the bass will sound). I suggest you go ported, 2.2cu/ft per sub tuned to 30-35hz (tune lower first and then chop the port until your happy with how it sounds).
    Black VZ SV6
    Dec 2005
    thanks for the heads up before i wasted money on a ported box.
    i have almost exactly 1.25cf for each... i must have them pretty spot on then... maybe i need to crank some more power into them
    Drive it
    Like ya stole it!
    Black VZ SV6
    Dec 2005
    now i don't know what to do! good job fellas haha
    Drive it
    Like ya stole it!
    VS Acclaim
    Jun 2006
    For hip hop music, i think that the improved low end is worth the switch to ported. The sealed rolls off at around 50hz compared to low 30's depending on tune in the ported. If your going to build the box yourself it'll only cost about $80 so its worth a try... cheaper then a new amp although you should definitely get one if you got the money. Ideally, if you know someone with the same sub in a ported box it'd be good if you compare them yourself...
    VK BROCK Group "A"
    Dec 2006
    KENMORE QUEENSLAND
    Joey has a valid point... though these SUB SOUND like CRAP in a ported box.. if you are playing any thing else by DOOF DOOF and DOOF DOOF gets BORING!!!
    Also depends how you have got them wired as they can be wired in the following configurations for one sub
    4 ohms - Bridged MONO - Parallel
    2 ohms - Stereo
    2 ohms - mono
    I just checked the dealers specs for a ported enclosure they are as follows
    Box Volume:..1.85 cuft
    Port Size:......3" Round
    Port Length:..6"
    These are for seperate boxes...for each sub
    Will put up the install manual in a minute
    Yes - Ported gives you better low bass but a a sacrific.
    VK BROCK Group "A"
    Dec 2006
    KENMORE QUEENSLAND
    Arrow
    Quote Originally Posted by Car Audio Factory Outlet View Post
    2 ohms - Stereo
    2 ohms - mono
    Port Length:..6"
    INSTALL MANUAL - Including SUB ENCLOSURES!
    ENJOY!
    Though I would Personally not use a ported box on these subs.... as they are too limited then. for SQ!~
    VK BROCK Group "A"
    Dec 2006
    KENMORE QUEENSLAND
    ENJOY!
    PS -- we have these types of ported boxes that for $149.00 each or the dual to the correct size is $189.00
    Black VZ SV6
    Dec 2005
    Orsm. Thanks for your replies!
    I have them wired in parallel @ 2ohms.
    I think i'll give the ported box a go...
    Drive it
    Like ya stole it!
    Black VZ SV6
    Dec 2005
    VK BROCK Group "A"
    Dec 2006
    KENMORE QUEENSLAND
    Where can i look at these enclosures CAFO?
    Can post some pics if you wish
    The one that Infinity does as well is perfect for the specs and port that you are chasing
    R21230DB
    or this one
    Subwoofer enclosure angled for mounting behind rear seats
    - 320mmH x 900mmW x 460mmD
    Black VZ SV6
    Dec 2005
    how do you order your products? i cant seems to find these enclosures on your website
    Drive it
    Like ya stole it!
    VK BROCK Group "A"
    Dec 2006
    KENMORE QUEENSLAND
    We dont put them up as they are custom tuned to sach individual Subwoofer
    So one size unfortunately does not fit all
    THe Infinity Enclosure would be the way to go in my opinion for a ported enclosure as they are extremely good and very easy to tune and adjust if needed.
    and it is SPOT on for your SUBS!!
    you will need to email sales@caraudiofactoryoutlet.com.au to order
    PS same price as quoted.
  15. #15
    Black VZ SV6
    Dec 2005
    does that include postage?
    would they sound better facing rear ward, or facing towards the seats?
    if facing rear was better i would try and find a box that does not have a angled face, because i want to put fake walls up and make it look neat
    Drive it
    Like ya stole it!
  1. Sealed, Ported and Distortion
    By azzfox in forum Car Audio
    Last Post: 08-08-2006, 03:56 PM
  2. Ported or Standard
    By Pub247 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 18-07-2006, 07:41 PM
  3. ported or sealed sub box
    By kyl'svs in forum Car Audio
    Last Post: 18-07-2006, 09:56 AM
  4. Application For Permission To Date My Daughter
    By kowan in forum Jokes/Humour
    Last Post: 16-02-2006, 06:38 PM
  5. streering wheels application
    By vnbelina in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-08-2005, 07:03 PM
