Hey guys,
Has anyone installed speakers in the driver and passenger door trims? Is there enough room to install directly into the trim without using pods and will the trim hold the weight?
These are only 16cm speakers
i dont beleve there is enough room, you will more then likley need pods.
Subscribe Here for our monthly Specials
ALPINE PIONEER Rockford Fosgate Scosche EFX JVC SONY INFINITY
They are 16cm, here a link to similar ones.
link
Hopefully I can get them in there without pods, took off the trim today and llooks like the should fit. Was just wondering if anyone had actually done it with otu the pods.
I have put some in .. But used pods... Just get som MDF wood, cut in a circle, and put some matching vinyl ... Apart from seeing some of the marks from where the map pocket was it looks quite good...
Or you could just get later model VR-VS or Statesman pockets which came with speaker pods and put them in ... That way it will look totally stock ...
Here is a quick pic...
I have some of the map pockets out of the calais that I took all the interior from, and when I feel the need I will pull out the dremil, and attack it so it fits...
Yeah looks good, I could try that.
Right behind the trim where you have your speaker there is a hole in the door that looks perfect for a speaker. I reckon the magnet would fit in there.
Yep, but there is not much room there for the magnet to fit through before it hits the glass... Wind down your window all the way and you will see...
A little off topic, but is that your bike ???
Ah yes the glass, I forgot about that! Don't have the speaker here but I will see what the clearance is like later.
No not mine, one of the guys at work owns it. Must get him to take me for a spin![]()
heheh ... ignore my PM comment then ... :lol:
Yeah once the window is down, there is not much clearence...
I'll have a play with it tonight and see how I go.
I'll post a pic if I can get it to fit in there!
No way they will fit without some sort of spacer.
The glass is back far enough but the regulator arm gets in the way when the window comes down.
Yeah, thought the chances were slim ...
Ive got vg ute, door trim i assume would be the same and i have got 6.5s in that spot where the hole is and i havent got any problems with puttin them there, im in the process of tryin to get my old 6.5s in the doors as well so im goin to have to make some pods or somethin though
yes it is possible, depends on the speaker itself mostly, u dont want to resort to cutting anything so get spacers or better VS door pods if u need them. here are sum pics of somebody that has put them straight in that i found on here a while ago.
http://forums.justcommodores.com.au/...1&d=1142316578
http://forums.justcommodores.com.au/...4&d=1142318024
I would be looking at this it not bad!
http://forum.******************/showthread.php?t=1878
Mate would not call that competetion!
It is like half the links on here going back to CAA or NissanSilva, boostcruising etc
Anyway someone has EDITED it!!!!
OK THEN!!
nobody edited it, jc has a list of blocked websites in which the name of it is automatically disabled with "*******" for example try and type street commodores in one word and it will do it.
And you learn something new everyday... nsw commodores com
Thanks guys, going with the parcel shelf I think, can't be bothered searching for pods or buying spacers, just want to get the things in there somewhere.
