+ Reply to Thread
Page 1 of 3 1 2 3 LastLast
Results 1 to 25 of 65
Thread: Will My Design Work???
    Keesh's Avatar
    Keesh is offline WATSON HOLDEN Keesh has disabled reputation
    VQ 5L Caprice, WH LS1 Statesman, VN 5L Calais
    Jan 2006
    Default Will My Design Work???
    im um gettn rid of my old box and designing a boot install atm! i was wondering if any of you tech guys reckn that 4775.5 cubic inch' (or approx 2.77 cubic Ft.) is a good size encloser per 12" sub and if i should port them.. or even run the one 5.5(approx) cubic Ft box for the 2 subs(ported or unported) thanx!
    Don't blame me, It's that damn percadan..
    If you ask me, that stuff rots your brain...
    And now a word from our new sponsor.. Percadan? oh crap!
    VS Acclaim
    Jun 2006
    Yes it will work but will it sound good - IDK. The box size and type is determined by the subwoofers T/S specs. without this info, no one can tell you anything helpful about building the box and if the sub is suited to ported etc.
    Keesh's Avatar
    Jan 2006
    sony specs indicate that enclosed i should go 32L or 1.2cubic ft and ported 28L or 1 cubic ft.. at the moment im running a double box and it works out to be 1.9cubic Ft. per sub.. and i want to run 2.7 cubic Ft. acording to my design. what effect will the increased box size have?
    Keesh's Avatar
    Jan 2006
    800peak
    250w rated
    93db sensitivity
    responds 25-800hz
    VK BROCK Group "A"
    Dec 2006
    KENMORE QUEENSLAND
    Quote Originally Posted by Keesh View Post
    Agree with JOEY anything will work -- sound any good -- think not !!!
    Need some detail of your subs and how many etc
    Subscribe Here for our monthly Specials
    ALPINE PIONEER Rockford Fosgate Scosche EFX JVC SONY INFINITY
    VK BROCK Group "A"
    Dec 2006
    KENMORE QUEENSLAND
    800peak
    250w rated
    93db sensitivity
    responds 25-800hz
    WHICH SONY SUB????
    because 250RMS doesnot EQUAL 800!!
    VK BROCK Group "A"
    Dec 2006
    KENMORE QUEENSLAND
    It will sound like SH!T
    how are you lining the box... are you allowing for free air..... what HZ are you tuning to?????????????
    So many questions --- so little time!!!
    Keesh's Avatar
    Jan 2006
    i dunno about any tuning.. audio isnt my feild.. im running sony XS-L1220R.. im talking about running 2 subs in total but each enclosure 2.7cubic Ft. at the moment they are in 1.9 ported and they sound nice.. sound like shit.. can u be more specific? more booming bass or bad response to high frequency?
    VK BROCK Group "A"
    Dec 2006
    KENMORE QUEENSLAND
    Fair enough!!
    Nice little sub -- let me come back to you in 5!
    CHeers
    The sound waves will be all distorted... no bass not high not anything.... just a mess... of sound waves.
    Will come back to you with what you should look at running!
    Keesh's Avatar
    Jan 2006
    id rather just make the box smaller.. the reason i made it that was cause i made it to the dimentions that would fit perfectly into the back of the vn, then id put the flat board across it ill post a pic of my sketch
    VK BROCK Group "A"
    Dec 2006
    KENMORE QUEENSLAND
    Make the box the size you want and then add some expand-a-foam the high density one and trim out to suit!
    you can use the bean method of measuring you box volume --- that is get a bag a bean bag beans and fill you box with them and then take them out using a bucket of a known volume that will give you the litres that it needs to be then you can add and subtract foam as needed
    That is the easiest way
    Will get back to you with some specs
    Keesh's Avatar
    Jan 2006
    u can see its made to go over the hump where the rear axle is i could just bring the back in more but then id be wasting all the space behing the seats
    VK BROCK Group "A"
    Dec 2006
    KENMORE QUEENSLAND
    Your sub is as follows
    Frequencies: 25-800
    Power - RMS: 250
    Must say I love SONYS - ESUPPORT !!! just such a Throw the dart at the wall and hope that you get something!!!!
    Anyway --- I just love the dealer support!!!
    Here are the specs for the enclosure
    Sealed Box Volume: Sony recommends mounting this woofer in a sealed enclosure with an internal volume of 1.15 cu/ft.
    Ported Box Volume: Sony recommends mounting this woofer in a ported enclosure with an internal volume of 0.82 cu/ft with one 3" Diameter x 12" Long port.
    Please not that this is for one sub... if you are making a box then I would make them in seperate chambers --- so they are independant to each other... sub to them not working real well together.
    If you want BIGGER BASS then go the PORTED! with the length and diameter of the port as this is TUNED to these subs!
    Keesh's Avatar
    Jan 2006
    what size would you recommend for these subs? just what sony said? its different to what they have in the manual i got with them
  15. #15
    VK BROCK Group "A"
    Dec 2006
    KENMORE QUEENSLAND
    I see said the blind man!
    you will need to adjust the volume dramatically -- either by lifting the base - board up into the box itself of putting in a false bottom or --- MY FRIEND and YOURS -- EXPAND-A-FOAM!!!
  16. #16
    VK BROCK Group "A"
    Dec 2006
    KENMORE QUEENSLAND
    The Manual will have a max and a min!! and sometime on the higher end a IDEAL that gives you something to work with
    Me... I would go with the esupport from sony which are the dimension I gave you.
    Or if you are happy with you dimension then go with them
    Though if you go the false bottom and close the space up to almost what the volume that I have given you then have a listen if you dont like it then you can drop the false bottom back down to where you think and test again to where you like the sound... just not on one piece of music try a few different tracks and artists.
  17. #17
    Keesh's Avatar
    Jan 2006
    um i have a question.. do u no how much area this sub might take up? ive drawn a quick box to get the new volume and its 470mmx435mmx210 subtracting the sub volume will this give me aprox 0.8ft3?
  18. #18
    VK BROCK Group "A"
    Dec 2006
    KENMORE QUEENSLAND
    You dont need to worry about free air or the volume of the sub as the cals have taken this into consideration!
  19. #19
    VK BROCK Group "A"
    Dec 2006
    KENMORE QUEENSLAND
    I get 1.51621 cu ft
    There is 35.314 cu ft to a cu meter!
    so your dimensions are .0429345 m3 * 35.314 = 1.516 cuft
    So unless you have a sub the size of KING KONG -- I would say your cals are wrong... plus you dont need to worry about the sub subtraction as it has been factored in with the volume that is recommended!
  20. #20
    phat_com's Avatar
    phat_com is offline VR IS A BEAST WITH NEW V6 phat_com Executive
    VR s2 Acclaim/VK IS GONE :(
    Jan 2006
    Tuggers (da hood),ACT
    make the sub box you want and then put wood inside the box to make it smaller or you could use that expander foam idea but i wouldn't say it would be any good?
  21. #21
    VK BROCK Group "A"
    Dec 2006
    KENMORE QUEENSLAND
    Quote Originally Posted by phat_com View Post
    You KNOW EVERYTHING TODAY!!!!
    So why do all the subwoofer boxes -- well the decent ones have DACRON in them???
    Or you fill yours with FREE AIR!!
  22. #22
    Keesh's Avatar
    Jan 2006
    um did esupport give you any dimentions? all i no is my box need to be 210mm deep.. any suggestions?
  23. #23
    Keesh's Avatar
    Jan 2006
    i mbuliding 2 seperate boxes so just dimentions for 1 sub
  24. #24
    VK BROCK Group "A"
    Dec 2006
    KENMORE QUEENSLAND
    NO!! none of them do... and that is the point!!!! - CUSTOM BOX!!
    Have to LOVE the CUSTOMER SUPPORT that other sellers provide!!!! -- especially SUPER CRAP!!!! and JB!!! and LETS NOT FORGET !!! EBAY!!!!!
    It will be hard for you to find information as it is a DISCONTINUED MODEL for over 9 months!
    NONE!!!!
  25. #25
    cammed Vx ss m6
    Sep 2006
    Quote Originally Posted by Car Audio Factory Outlet View Post
    NONE!!!!
    all your capital letters and words remind of those adverts where a company is sellng doors or windows and they shout then talk then SHOUT!!!
+ Reply to Thread
  1. need a design
    By COO1VS in forum General
    Last Post: 05-05-2007, 04:01 PM
  2. Rim Design??? help me out...
    By sno in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-11-2006, 12:07 AM
  3. Which Design Do you Prefer?!?
    By HoZy in forum Just Commodores Polls
    Last Post: 16-09-2006, 08:43 AM
  4. Sub-box design (no this hasn't been posted)
    By rannex in forum Car Audio
    Last Post: 13-08-2006, 01:12 AM
  5. Sub Box design???
    By Cameron in forum Car Audio
    Last Post: 07-10-2005, 08:18 AM
