Results 1 to 17 of 17
Thread: Amp keeps cutting out?? PLS HELP
    BLOWN VS
    Jun 2005
    Cairns
    Question Amp keeps cutting out?? PLS HELP
    hey people,
    i was wondering if anyone could help me with my amp problem. It works perfectly fine then cuts out, works fine, cuts out so on and so on. it sometimes dosnt even work when you just start the car so it cant be overheating although it does get fairly hot. anyone got any ideas, any help will be appreciated.
    thanks
    Check out my ryde!!!
    http://www.cardomain.com/ride/2040074
    ohhh yeah.....only milk and juice come in 2 litres
    Boonz's Avatar
    Boonz is online now the holden mechanic
    green 355 VG ute , silver vx s pac L67
    Jul 2005
    berri, south australia
    maybe your signal wire isnt making proper contact and cutting the power???
    VK 5litre, GSXR600
    Jan 2007
    gladstone qld
    BLOWN VS
    Jun 2005
    Cairns
    thanks for the replies, i should have mentioned that i've re joined all wires since this problem has been goin on for and still does it.
    VK BROCK Group "A"
    Dec 2006
    KENMORE QUEENSLAND
    Quote Originally Posted by Holdenboy_VS View Post
    Check the Earth for the AMP and you have proper contact with the fuse in the holder...
    Have you put a multimeter on it at the amp??
    Subscribe Here for our monthly Specials
    ALPINE PIONEER Rockford Fosgate Scosche EFX JVC SONY INFINITY
    BLOWN VS
    Jun 2005
    Cairns
    nah i havnt put a multimeter on the amp..... dont really know how to use one properly lol.......... will check earth again 2morrow as well as fuse but pretty sure ther all 100%
    VK BROCK Group "A"
    Dec 2006
    KENMORE QUEENSLAND
    If you have a multimeter -- can tell you how to check it!
    sounds like that it is either a trigger wire or it is earthing somewhere
    Suggest that you plus a good star washer under the connector for the earth for the amp so you get a nice meaty GROUND!
    Though it may be the fuse in the holder not making good connection! this is an easy one as it will cause some HEAT well a lot of heat!
    What AMP is it!??
    wrx884's Avatar
    wrx884 is online now WA's ASR Rep
    VT Commodore Exec/5L VP Calais
    Mar 2006
    i had the same problem 1nc was the fuse holder the metal casing on the lil fuse itself they kept coming loose on the ends found some decent 1ns and it hasnt done it since
    Check out my ride in progress.... 98 VT V6, V8 Supercar kitted
    Daily toy.... 92 VP Calais 5L
    05 vz
    Jul 2005
    is the speaker wire in to far and touching the speaker basket or ya ohms are all wrong
    i was trying to run a dule 4 ohm 12'' sub off a amp that could run a dule 2 ohm sub and getting beefy bass but it was giving a signal on the mutimeter at the sub of 0 ohm which was making the amp work over time, it would over heat and a safety thing would shut it off
    thats what i understand from what was happening to mine, but im prolly way off
    theres heaps of things to consider, even a screw that holds a speaker could be touching the body of the car
    VY SS
    Aug 2004
    SE Victoria
    Quote Originally Posted by itchy pits View Post
    could 've 'ave found 'ze anzswer to zie uni-verse? (in a german-genius accent)
    BLOWN VS
    Jun 2005
    Cairns
    cheers for the replies guys, this afternoon i have moved the earth to a new position and fiddled around with the fuse and holder..... left the player on for about 10mins n was runnin fine but will see tomorrow after the drive to work n back whether or not it'll cut out.......
    BLOWN VS
    Jun 2005
    Cairns
    well it still keeps cutting out........ ive pushed the fuse holder thigy's together so its a tighter fit and still nuthn.... any more ides???
    VK BROCK Group "A"
    Dec 2006
    KENMORE QUEENSLAND
    NEW AMP!!
    wrx884's Avatar
    Mar 2006
    try new fuse holder i tried that with mine and didnt fix it got a distrubution fuse block instead and i havent looked back since
  15. #15
    BLOWN VS
    Jun 2005
    Cairns
    dont have the money for a new one jus yet.... but i do need another one for my 2x10''s.... that are waiting to go in
  16. #16
    VY Acclaim Wagon
    Jan 2007
    if u read my posts from the other day you'll see that i had problems with my amp working, it ended up being the fuse but i couldn't tell for ages. It looked fine and the resistance across it was zero. It ended up being a blown one, but right on the end where u couldnt see, and cause it didn't blow completely it still gave zero resisance when i tested it. The only reason i found it was cause i tested the voltage across the amp, when it was running there was only 1 volt across it. It's unlikely you've got the same problem, but it's worth a look
  17. #17
    Burnout_bro's Avatar
    Burnout_bro is offline Donating Member
    HYPER VX SS/ R33 GTST
    Dec 2006
    mine did the exact same thing got it checked out today and they said ur amp is ****ed and it was only 2 weeks old, never buy a ****ty amp lol
  1. VN V6 cutting out
    By Shortstuff in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-01-2009, 04:35 PM
  2. VP Air Con cutting out
    By VP-Matty in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-06-2008, 10:18 AM
  3. VR ss cutting out
    By SERGE in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-03-2007, 12:12 PM
  4. Amp cutting out!!
    By donz in forum Car Audio
    Last Post: 01-11-2006, 08:37 AM
  5. VX a/c cutting out
    By VX_GIANTZ in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 31-10-2005, 10:24 PM
