i have a jvc exad headunit, & was wondering if its possible to get an electric aerial to work with it?
yeah you hook the dark blue wire to the power side of the electric aerial and it sends away 12 volts to the motor and up she goes![]()
Subscribe Here for our monthly Specials
ALPINE PIONEER Rockford Fosgate Scosche EFX JVC SONY INFINITY
ahhh, little more info
oh, just one more question, by doing it that way, is it goin to work only when the radio is on? Or will it be up when the car is on?
is there anyway, i could make it so it only goes up when i have the radio on?
what i mean is, can i have so it only goes up or down when the radio is on? Like if im listening to a Cd it wont be up
when i get around to it, ill post up in the thread if i have trouble, my XU6 aerial should be electric, shouldnt it?
Ive been tryin 2 get the same answer on this forum 4 ages all ive got in reply thats worth knowing about is that the aeral will always b up if u use the remote/aeral wire (blue) unless u have a 2nd wire in the HU harness it wont go up n down wen the radio is only on like u want it. that 2nd wire cuts the power wen u switch it over 2 radio thats how they r supposed 2 work.
my only thing i can think of is 2 tap into that remote wire and run another wire with a switch and then u can turn it on n off urself kinda defeats the purpose of an automatic aeral lol but like u, u prolly dont wanna park ur car and have 2 push down the aeral manually like me haha?
My JVC head unit has 2 seperate wires - a blue one for the remote amp switch, and another blue (with white stripe?) one for the aerial. I pluggged that wire into the factory loom's aerial wire and it works fine - only goes up with the radio, and stays down for CD, DVD etc.
Some lower spec head units don't have a seperate aerial wire, just a trigger than can be used for amps, aerials and everything else. In that case, your aerial will be up whenever your head unit is on, regardless of which music source you are using.
