Hey All
I just got an amp today for my sub, i can get the amp to work but not the sub... its just the sub connected to the amp, the other speakers run off the HU.
Do i need more then 1 rca cable? like one to sub then amp, then other from amp to HU?
The subs an Boss BA1090 sub max 1000w, wish i knew the the lowest power watts it requires... i've looked everywhere![]()
Hey Goon, is the sub goin to be the only thing runnin off the amp?
That amp i think is a 4ch....
Plug the 2 rca plugs into channel one and two, then u just run the sub off those channels.
If that amp is bridgable then u can wire the sub + to ch1 + and the sub - to ch2 - if it needs sum more power which i think it will.
But its all depending on wat power and if its dvc.
Hope that helps ya.
My amp is just a 2 channel, i brought it just for the subwoofer.
Power - accessorys
Ground -Earth
System control - HU amp wire ? its what i did..
Speaker output R-+ L -+ <-- subwoofer here?
^^ they are all on the one side.
The other side of the amp
Speaker input. <<-- square connection. 4 smller squares
Input white L red R <<--- RCA cable to HU?
Set LPF on for sub?
gain is set to normal atm..
the amp is bridgeable so in the future im buying another amp for my 6x9's
Subscribe Here for our monthly Specials
ALPINE PIONEER Rockford Fosgate Scosche EFX JVC SONY INFINITY
everywhere has pathetic service besides your own ay
Also, the power wire on the amp needs to be connected directly to your battery with adequate size wiring and a fuse holder within 30cm of the battery. The power wire is not accessories.
yer easy mistake tho not many ppl relise u need an amp kit was like with that job i did the other week i told ya bout the bloke only bought RCA cables lol but not every1 knows so u can only help em learn ay
2 b honest strathfield, jb hi fi ect dont care about advice or sounds gear they really just wanna throw ne audio gear at u that they have in store and sell it not caring bout how it will all sound 2gether or wat budget ppl r on by doin that really makes u stop n think where the good old fashion service that the lil idependant competitors can give u ay id go 2 them neday over the major compaines like them, even if it means spending that lil bit extra i think its worth it least u know u'll get looked after
neways sorry 2 get off topic lol
YES!!! --- no good on the negative side as the damage will be done if there is a short...
.... just a word of WARNING!!!!! dont hook the RCA to the HEADUNIT if you have the igition on or power to the HU as you will BLOW the CIRCUIT PROTECTOR on the Pioneer..... and VOID the WARRANTY!
Thanks again mate, my HU is sony xplod has it on the back of the unit.
I havent tried it out yet, sitting down to a![]()
Thanks heaps again mate for answering my questions![]()
May i ask if Bronze is negative or postive? - speaker wire..
I don't wanan screw anything over, its my first go at this advance sound system stuff, a standard setup i understand![]()
if you speaker wire is bronze and silver that is dosn't matter if you connet bronze to - or + just as long as its +to+ and -to-. I'll make a littlwe picture in paint to help you out.
