Results 1 to 11 of 11
Thread: System help
    dmitch's Avatar
    dmitch is offline DonkeySS
    VS SS S2
    Oct 2005
    Perth W.A
    Default System help
    doin a system for my fiance and so far thinking of this i know the front doors r gonna need 2 b modified to fit 6" in an excel
    Pioneer 5850MP
    MTX Audio TX6001 Splits
    now i just need a good amp and sub for less than $500.. ne1 got ne ideas thanks..
    Check out my ride and rate it high plz
    VK BROCK Group "A"
    Dec 2006
    KENMORE QUEENSLAND
    Quote Originally Posted by dmitch View Post
    Pioneer 5850MP
    4 , 2 or mono ??
    Subscribe Here for our monthly Specials
    ALPINE PIONEER Rockford Fosgate Scosche EFX JVC SONY INFINITY
    dmitch's Avatar
    VS SS S2
    Oct 2005
    Perth W.A
    wat would b best 4 running the splits and sub.. or would the deck b good enough to run the splits and a mono 4 the sub.. i dont know that much about sound systems or should a get an amp 2 run both of them
    VK BROCK Group "A"
    Dec 2006
    KENMORE QUEENSLAND
    Best is to have a mono for your sub and a 2 channel for your splits
    you need an amp to run splits unless you dont use the crossovers and tweeters.
    You can use a 4 channel and bridge two channels to run the sub though would not recommend it! and you will need a D2 or similar sub so you can wire it to present 2 ohms.
    VK BROCK Group "A"
    Dec 2006
    KENMORE QUEENSLAND
    If you are chasing a sub and amps let me know as we should be able to help you out with the right package and budget!
    dmitch's Avatar
    VS SS S2
    Oct 2005
    Perth W.A
    wats a D2 sub.. and y wouldnt u recommend getting a 4 channel and bridgin 2 channels..
    VK BROCK Group "A"
    Dec 2006
    KENMORE QUEENSLAND
    2 ohm sub instead of a 4 ohm if you are doing down the 4 channel amp route.
    No I would not recommend the 4 channel bridged as it is the TIGHT ARSE approach and not a very good one at that ..... though it does work... if you are on a budget... but dont expect miracles out of your system!
    dmitch's Avatar
    VS SS S2
    Oct 2005
    Perth W.A
    one of the amps im lookin at is a 4x100 that can do Power / bridged @ 4ohm 14.4V: 380WRMS x 2 does that mean it can run a 4ohm sub or only a 2ohm.. it doesnt need 2 b a mega loud kick ass system.. just something that will go alright with decent bass.. and money is abit tight atm can only afford about 500 for sub/amp.. but was thinkin of a 4 channel to do both atm.. and when got abit of extra cash get a mono amp 4 the sub..
    VK BROCK Group "A"
    Dec 2006
    KENMORE QUEENSLAND
    Which means you can only run it as a two channel --- not good! unless you put the splits on one channel and the woofer on the other. I should have said that you need an 4 channel amp that will TRIWAY! the cheap ones dont!
    The Rockford ones will
    dmitch's Avatar
    VS SS S2
    Oct 2005
    Perth W.A
    will this is the specs of the amp will it b able 2 run the splits on 1 channel and sub on another atleast until we can afford a mono amp aswell..
    Response Car Amp 4x100WRMS *$299
    If you are looking for an ultra-powerful 4-channel amplifier then the AA-0426 is an excellent choice. Power output exceeds 100WRMS power channel or 300WRMS in bridged mode at 4ohms, making it ideal for a one amplifier system powering both full range speakers and a subwoofer. There’s also fully variable high and low pass filters between 50Hz and 500Hz, with pass thru RCA outputs to link this amp to an additional AA-0424 2 x 150WRMS amp to drive your subwoofers, or better still the amazing new AA-0428 Class-D subwoofer amplifier.
    Specifications:
    Power / channel @ 4ohm 14.4V: 130WRMS x 4
    Power / channel @ 2ohm 14.4V: 190WRMS x 4
    Signal/Noise ratio: >90dB
    Input sensitivity: 200mV to 5V
    Low pass filter: 50 - 500Hz @ 12dB/octave
    High pass filter: 50 - 500Hz @ 12dB/octave
    Pass thru RCA: Yes
    Dimensions: 400(L) x 258(W) x 50mm(D)
    VK BROCK Group "A"
    Dec 2006
    KENMORE QUEENSLAND
    Specifications:
    Pass thru RCA: Yes
    BUT ARE THEY TRIWAY??
    You would have to have rocks in your head if you think that this will run a sub and splits at the correct RMS, HZ etc.
    Even the Sony XMSD46X is Triway .... again RMS is not EVERYTHING
    If you bridge two channels to run the sub and then two channels to run the SUB you might as well KISS your MTXs CONEs GOODBYE!!!!
    Let alone a CHEAP SUB!
  1. vn lpg system in vr
    By stackner in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-09-2006, 11:50 AM
  2. system cut out
    By REVDUP in forum Car Audio
    Last Post: 05-03-2006, 12:07 PM
  3. Is my system ok??
    By MTX_15inX2 in forum Car Audio
    Last Post: 07-12-2005, 04:45 AM
  4. System set up????
    By Jarro_sparrow in forum Car Audio
    Last Post: 17-08-2005, 05:38 PM
  5. Vr System
    By PIMPIN in forum Car Audio
    Last Post: 29-01-2004, 06:23 PM
