Results 1 to 12 of 12
Thread: Where have you got your Crossovers mounted? VR-VS
    VR V6 5spd '93
    Nov 2006
    Southern NSW
    Default Where have you got your Crossovers mounted? VR-VS
    Hey all, im going to be putting splits in my car in the next couple of days. I was just wondering where you all have your crossover box mounted?
    Thanks
    Burt_vn's Avatar
    Burt_vn is offline Back in the game
    VG V8 5spd, 400hp 5spd soarer, vq stato
    Jan 2007
    Gold Coast
    Mine are behind the door trim, sitting on the plastic water cover. But if you want yours to be seen just cut a hole in your trim somewhere, and poke them out. I mounted my tweeters on the little plastic plate that has the mirror adjuster on it.
    VG ute, 5.0lt, 5spd, twin exhaust, cam etc.
    VQ stato, 5.0lt, auto, pretty stock
    TT Soarer, 400rwhp, 5spd, lots of mods.
    VR V6 5spd '93
    Nov 2006
    Southern NSW
    Inside of the door trim ay.
    Ill probly have a good look at mine when i come to mounting them, i dont want to pull all the dash out and then put it back on to drive and then have to pull it all back out to mount the tweeters in under the fake vent holes that need cutting out
    Burt_vn's Avatar
    Jan 2007
    Gold Coast
    Yeah, just have a look around, theres plenty of places to hide the crossovers, and plenty of places to mount the tweeters. Keep in mind you want the tweeters somewhere close to you so you get their proper effects, treble doesnt travel through things well.
    VR V6 5spd '93
    Nov 2006
    Southern NSW
    ill probably stick them right up next to the vent, meh, see what happends.
    Thanks for the reply though mate
    Burt_vn's Avatar
    Jan 2007
    Gold Coast
    No worries.
    VX SS 5.7L M6
    Jul 2005
    W.A. Perth
    Tasmaniak's Avatar
    Tasmaniak is offline Not a valid input....
    car
    Apr 2005
    On all the commodores I've done I've always put them in the same place..time after time!
    Under the glove compartment is a black pllastic panel stopping you from seeing up under the dash. I've always removed it, bolted the crossovers to that and reinstalled it.
    The main reason I do that is simply because the crossovers are typically the first component to fail. Also, if you lose sound up front you need a quick easy place to check if the sound is still getting to the speakers without ripping the doors apart.
    VX SS 5.7L M6
    Jul 2005
    W.A. Perth
    Quote Originally Posted by . View Post
    isnt that only on the statesmans?? i have a vn and vn ss neither of them have one maybe they put them in everything after vn.
    13.3 1/4 exhaust only untuned!
    wrx884's Avatar
    wrx884 is online now WA's ASR Rep
    VT Commodore Exec/5L VP Calais
    Mar 2006
    yer ive always been told NOT 2 put the crossovers in the doors 4 the same reason by . (<thats the dudes name btw) hahahaha plus coz ur opening n closing the door all the time u risk the chance of them failing more kick panels r usually the best place 2 hide them
    Check out my ride in progress.... 98 VT V6, V8 Supercar kitted
    Daily toy.... 92 VP Calais 5L
    Tasmaniak's Avatar
    car
    Apr 2005
    thats true...don't put them in the doors...plus it's not exactly waterproof! I don't remember that panel being there in VN-VP sorry...my bad! I do know it was there on the VRs
    VS Executive
    Apr 2010
    Sydney NSW
    In my first VS I had the crossovers mounted under the door trim under the arm rest where the most room is
    and I had the tweeters just on the front of the door trim (I didnt have window rollers)
    im currently installing my system in my new VS (with window rollers) and I attatched the tweeters on the midranges and put them in the door pod together
    the crossover is floating around in the arm rest atm too, I have to secure it haha
    but yeh im planning on moving both those, but still on the door, its easier to wire and you dont need to buy extra wire or cut holes
  1. where have you mounted gauges
    By defa in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-12-2006, 06:27 AM
  2. Where to put crossovers?
    By sganro in forum Car Audio
    Last Post: 16-10-2006, 04:42 PM
  3. Where to put crossovers in VZ Ute???
    By onefifty in forum Car Audio
    Last Post: 23-07-2006, 08:33 PM
  4. how do u wire the crossovers in a VS
    By moz_and_paul911 in forum Car Audio
    Last Post: 05-08-2005, 05:02 PM
