Results 1 to 20 of 20
Thread: So where to now???
    Jan 2007
    Post So where to now???
    hey, thought i might ask you pros out there for some advice...
    Currently in my VR wagon, Ive got a good sony headunit, 350 watt 6X9s, 600w sub and amp, and some tidy 200w 6"ers in the front. i was wondering what i should do next?
    i was thinking about sound dead'n under all the door trims and tailgate, but i also also had the idea of using expanding foam in the rear quater panels (Getting access by removing 6X9's). would this be the next thing i should focus on? or has anybody tried doing this in a VR wagon before?
    Any help would be greatly apreaciated
    VS Acclaim
    Jun 2006
    Before i answer, id like to ask you what it is about your system that your unhappy with?
    Jan 2007
    im not unhappy with it, i just want to get more out of it, just so its that little bit better
    VS Acclaim
    Jun 2006
    Leaving the gear the same, you will gain most benefit from sealing and deadening the front doors. This should improve mid bass and help bring your soundstage forward. Unless you got rattle i wouldnt bother about expanda foam in the back quarters - if your running a sub, you should have your 6x9's high passed anyway.
    If your prepared to spend more, i recommend buying a 2 channel amp for the fronts. This will cost only slightly more then it costs to seal and deaden the doors.
    Jan 2007
    VS Acclaim
    Jun 2006
    Can do, but your system isnt very powerful so it wont make an audible difference.
    Jan 2007
    VS Acclaim
    Jun 2006
    Theres an excellent tutorial on this matter at CAA: To do it properly will still cost you some dough...
    http://www.caraudioaustralia.com/con...p?contentID=19
    Other members here can speak to the improvements this will make. IMHO i would amp first. I think theres more value in that for your system. Ideally do both. Someone else will pop up with an opinion soon
    Jan 2007
    thanks for the link im sure it will help me as well as a few others, that a good resource site!
    2004 VY2 SV8 A4
    Jun 2005
    Victoria Point, Brisbane
    I think sound deadening is an often overlooked way to get massive improvements in sound quality. I actually noticed when I moved all my audio gear from my old VS, which was an equipe, to the new Calais, despite it being exactly the same audio gear, the sound was far better quality due to the extra sound deadening in the Calais. I cannot recommend good quality deadening enough. Quality over quantity I always say... its all well and good to listen to music at a million decibels but if it sounds like crap then why bother?
    * Phreddy's Blaupunkt Aux input and line out mod
    * 18x8 inch Equus Kalibur Wheels with Maxxis MAV-1 235/40R18
    * Sureflo 3.5 inch medium-loud cat back exhaust
    VK BROCK Group "A"
    Dec 2006
    KENMORE QUEENSLAND
    Quote Originally Posted by shaggerz View Post
    Well said.... standard should be a good OFC wiring kit and Sound Mat. on ANY INSTALL.
    Though I guess it may cost what some people are spending on there speakers or Hu -- if they go the budget end like response etc.
    But like you have stated .... HUGE IMPROVEMENTS!
    True with SQ as the 171PRS component speaker from Pioneer which are there top of the line 6.5" are one of the nicest speakers that we have heard... and they are only 50 RMS on the spec though I would say they are more than that... plus they can handle double that everyday of the week 24/7
    Subscribe Here for our monthly Specials
    ALPINE PIONEER Rockford Fosgate Scosche EFX JVC SONY INFINITY
    VK BROCK Group "A"
    Dec 2006
    KENMORE QUEENSLAND
    Quote Originally Posted by Joe Peeps View Post
    Joey the TUT is Good, though as most people mount there speaker inside the outer shell of the door then the sound mat is a bit excessive on the outer shell
    The major problem is the Back Wave from the Speakers ... which then VIBRATE the DOOR SKIN like hell... especially on cheap import of for that fact most new cars as the door skins are waffer thin at best.
    So the effect is like a big drum skin, this is why when you add good quality sound mat like accumat etc you will get a huge improvement out of even just basic speakers.
    This is also why people often comment that the T162S from RF sound Tinnie... it not that they do as they are one othe best 6.5" on the market... but from the doorskins taking out alot of sound waves and causing noise or wave cancellation... hence the sound.
    It is more noticable with better speakers....though again a good investment for any splits in the doors front or rear.
    Even the sound cones for 6*9 in the rear make a huge difference.
    VS Acclaim
    Jun 2006
    So your saying that you would Seal and deaden before getting an amp? say you had $250 - ie you could properly do the doors with dynamat, or you could buy an amp, which would provide the most benefit to the system. i sealed my doors after i got an amp so i cant tell you from experience, but i suspect that the amp is a more valuable addition, because it will improve performance and he can always sell it afterwards
    VK BROCK Group "A"
    Dec 2006
    KENMORE QUEENSLAND
    Joey
    It would depend what you had to work with in the first place with speakers.... OEM and add an amp... my opinion would be better to go the sound mat.
    So the amp is overpowered for the OEM speakers anyway... and a door kit is only half of what you have said
  15. #15
    VS Acclaim
    Jun 2006
    Yes, but they arent the original speakers, described as 200w 6ers.. so im gussing about 60RMS? And can you properly do both doors with a single door kit?
  16. #16
    VK BROCK Group "A"
    Dec 2006
    KENMORE QUEENSLAND
    The Doors kits that we have are not single door kit as what is the sense in only selling single kits???
    They are Double and YES are a great improvement....
    I still say for the $150.00 they are half the price on an amp and will give you more than half the gain of an amp...
    SO yes good value for money.
  17. #17
    VS Acclaim
    Jun 2006
    LOL i realise a door kit is for both doors mate, i'm just saying i know a few blokes who have found a door kit insufficient in terms of square meters to PROPERLY do both doors. Maybe they went overboard And an amp can be resold - you cant really sell your doors... well, i guess you can but you get my point. Plus, you can get a decent 2 channel for 200ish. Or a good 2nd hand one
    *Woo hoo, my 100th post*
  18. #18
    VK BROCK Group "A"
    Dec 2006
    KENMORE QUEENSLAND
    for your 100th
    They must buy the cheapest they can find or like the RF only one roll.
    The ACCUMAT for instance has TWO(2) 305mm * 605mm sheets per door.
    THat is .4 sq meter
    You generally dont need to do the whole door as the door skin does not flex where it meets the door frame... plus like any acoustic material ... more is not better as it gets to a saturation point... so more is a waste of effort, time, materials and money.
    We find that two sheets of the ACCUMAT per door is more than enough unless you have a Diawoo or similar with FLAP for Doors and tin foil for door skins ... Kia are in the same boat.
  19. #19
    AirStrike's Avatar
    AirStrike is offline Site Administrator
    2009 G6ET
    Jun 2003
    Quote Originally Posted by Car Audio Factory Outlet View Post
    for your 100th
    THat is .4 sq meter
    Correct, on my mates VT we just covered all the holes in the door frame with the matting.
    Selling FG G6E Turbo and buying a N/A Supra
  20. #20
    Jan 2007
    thanks guys, that has been really great help. the idea of the reselling of the amp way a good consideration. but i guess matting would also take away a small amount of road noise as well???
LinkBacks (?)
  1. 01-01-2009, 06:57 PM
