Results 1 to 5 of 5
Thread: Panasonic Head deck wiring /aerial problem
    vr ss Commodore
    Feb 2005
    Gold Coast
    Default Panasonic Head deck wiring /aerial problem
    This one probably crosses over to electrical as well??
    I have a panasonic Head deck and I have wired it in properly as per wiring diagram. Problem is Blue wire which goes to electric aerial now doesnt put aerial up when radio is selected??
    With factory Head Deck when radio was selected aerial went up, when cd was selected aerial went down.
    I disconnected the blue wire.
    Now....
    The aerial goes up but doesnt stay up, comes straight down again. That is operating it with the up/down switch on the dash, seperate to the sound system.
    Is there a seperate fuse for the electric aerial??
    If it was blown aerial wouldnt work at all would it???
    The fuse in the fusebox for aerila is fine....
    Any ideas please, I hate wiring hassles!!!
    VR Commodore SS
    DBA Gold Rotors
    Lukey Exhaust
    Cold Air Induction / KN Filter
    185 KW Chip
    HSV Maloo 18x8 / Toyo Teo Plus
    Head Unit: Panasonic CQ-C3401W
    CD Stacker: Panasonic CX-DP801
    Front: Pioneer TS-C1602
    Rear: Pioneer TS-A1670S
    Bass: 2 x Pioneer TS-W255C
    Amp: Coustic 401DB Monoblock
    wrx884's Avatar
    wrx884 is online now WA's ASR Rep
    VT Commodore Exec/5L VP Calais
    Mar 2006
    check if the blue wire has power running throught it with a test light also if theres none try turning it on 2 radio and check again
    Check out my ride in progress.... 98 VT V6, V8 Supercar kitted
    Daily toy.... 92 VP Calais 5L
    VK BROCK Group "A"
    Dec 2006
    KENMORE QUEENSLAND
    Quote Originally Posted by wrx884 View Post
    Or the panasonic may be a - output hence it not powering the Aerial.
    Like WRX884 said test light or multimeter --- if you are not getting any reading on with the testlight earthed try it some power.
    Subscribe Here for our monthly Specials
    ALPINE PIONEER Rockford Fosgate Scosche EFX JVC SONY INFINITY
    vr ss Commodore
    Feb 2005
    Gold Coast
    What I am thinkin is??
    If I splice the blue amp wire into the electric aerial wire maybe this will make it work????
    The wiring diagram says blue wire is for amp relay control power lead, and in brackets....motor antenna relay control...
    Do I need to splice the blue wire into antenna as well, as it is only running to amp at the moment....
    VR Commodore SS
    DBA Gold Rotors
    Lukey Exhaust
    185 KW Chip
    Tasmaniak's Avatar
    Tasmaniak is offline Not a valid input....
    car
    Apr 2005
    seems a little odd....what I would do is simply remove the blue antenna wire and simply wire the cars antenna wire to the amp wire. This will send the antenna up when you switch the HU unit and down again when th HU switches off. It won't matter what source is selected.
    StoneX would have a better working knowledge of the interior workings of a HU then all of us. Hopefully he can shed some light on it. To me it almost sounds like the HU is sending out a pulse instead of a continous signal. In which case a latching relay would solve the issue...but on that same hand, if this was a common issue I'm sure I would've known about it by now so thats why I say StoneX....but then again, I could be about to learn something new...or relearn something I've forgotten in my time away from Commodores and power antennas.
  1. completed aftermarket head deck install
    By ris00 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 29-06-2009, 07:28 PM
  2. got my clarion head deck
    By cxcxcxvcvcvc in forum Car Audio
    Last Post: 10-12-2007, 10:00 PM
  3. good head deck for 700 bucks????
    By belave in forum Car Audio
    Last Post: 25-04-2007, 06:10 PM
  4. mounting head deck without brackets :(
    By ilovemyvx in forum Electrical Wiring / Questions
    Last Post: 22-05-2006, 08:10 AM
  5. Installing Sony CD head deck in 91 VP
    By VB Owner in forum Car Audio
    Last Post: 09-04-2006, 03:21 PM
