Page 1 of 2 12 LastLast
Results 1 to 25 of 30
Thread: 6x9 installation
    Aug 2005
    Default 6x9 installation
    hey guys, just wanted to ask a quick question. i bought some hertz 6x9 speakers and was woundering how to install them in rear parcle shelf of a vy commordore.
    Thanks
    daron's Avatar
    daron is offline wizfiz
    VE SSV
    Mar 2006
    adelaide
    remover rear seats
    remove rear shelf
    punch out the 6x9 metal plates
    install 6x9's
    run wire to either a rear door spkrs and disconted the door spks or run wire to deck and discont rear door spks and add the 6x9
    and no ya cant run 6 spkrs b4 ya ask
    not without amp
    Aug 2005
    Thanks fir that. Is their a way to installl 6x9 without removing the parcle shelf, or does it have to come out. how do i secure the speakers on the sehlf? Sorry first time doing all this hehe.
    Thanks
    RUN41T's Avatar
    RUN41T is offline Go forth and modify
    Vy SS
    Jun 2006
    Wollongong
    U only have to remove the parcel tray trim, then punch out the sheet, it only has 4 small spot welds. U may have to cut the parcel tray and put in the mesh inserts depending on weather u have em or not.
    U can just screw the 6x9's straight into the steel.
    VT Executive S1
    Jan 2007
    Quote Originally Posted by daron. View Post
    remover rear seats
    remove rear shelf
    install 6x9's
    not without amp
    I am running 6x9's. splits at the front and back. thats um 6 speakers... all off my headunit... well one of the back ones is unplugged. so thats 5 speakers. So you can run them all off the headunit cant you?
    Computer/Networking Problems? Contact me
    Check out my ride! First car!
    http://forums.justcommodores.com.au/...ad.php?t=49696
    daron's Avatar
    VE SSV
    Mar 2006
    adelaide
    VT Executive S1
    Jan 2007
    no you shouldnt
    specially an odd number
    *shakes head*
    Why not :S Its how i got the car? Should i change it asap? Behind the headunit is a lil messy. its got i think the factory plug its like a rectangle thing. then its got wires coming out of that into the kenwood one.
    What should i do?
    daron's Avatar
    VE SSV
    Mar 2006
    adelaide
    shrugz
    dont ask me ive only been intalling for 16 yrs
    just kiddin
    ya shouldnt run it like that
    also 4 good spkrs are better then 6 average ones
    or 5 in your case
    VT Executive S1
    Jan 2007
    What if i got all 6 good ones
    I was planning to replace all 6. Is this a mistake or what? Also planning to run them off a new headunit. My plans were to replace my current kenwood headunit for a 2007 pioneer one. Then upgrade the speakers as far as my money permits. assuming it would all run ok off the headunit?
    Or am i making a big mistake?
    Was thinking all pioneer speakers to btw if it matters.
    Aug 2005
    how do i cut the parcle shelf? do i use a stanly knife also how do i remove the metal plates underneath?
    Thanks
    wrx884's Avatar
    wrx884 is online now WA's ASR Rep
    VT Commodore Exec/5L VP Calais
    Mar 2006
    metal plates should just punch through prolly easiest with a hammer and old screw driver or chisole
    Check out my ride in progress.... 98 VT V6, V8 Supercar kitted
    Daily toy.... 92 VP Calais 5L
    VT Executive S2
    Jun 2005
    Morayfield - QLD
    Quote Originally Posted by Heffer_Slayer View Post
    you would be better off getting 4 speakers and spending the extra money on the front ones and maybe getting an amp for them.
    if you are not getting a sub get some 6x9's for the back and some splits for the front. run the back speakers off the head unit and the front ones off an amp. if you have enough money power the 6x9's off the amp as well.
    also note that SOME pioneer head units USED to be able to have two of their channels bridged to run a small sub. i don't know if they still offer head units that have this feature.
    VT Executive S1
    Jan 2007
    So is it really bad that im running 5 speakers off the headunit? Will it damage it if you run the 5/6 on them? Or are you just suppose to run 4. im confused.
    VT Executive S2
    Jun 2005
    Morayfield - QLD
    they are designed to power four loads. each of which is 4 ohms or more. so technically if you connected the speakers in series and not parallel it won't do any harm to the head unit.
    if you have your heart set on 6 speakers. get 6 speakers. it's not going to sound any better.
  15. #15
    VY Series 2 SS
    Oct 2006
    brisbane
    Quote Originally Posted by kingvt View Post
    Thanks
    go get some grilles first i got mine from northfield probably get them anywhere then cut out the parcel shelf with a stanley knife leaving little bits so you have something to hold up the grilles. it should look something like in the picture thats how i did mine. get s screwdriver intot he metal plate things and lever them off.
    ive put 6*9's in my parcel shelf and left all the other standard speakers in.
    i run the 6*9's off an amp in the boot.
    Did everything my self its very easy new head unit and speakers in parcel tray without cutting a single wire and no hacking involved.
    Attached Thumbnails Attached Thumbnails 6x9 installation-speaker-grilles.jpg
  16. #16
    Aug 2005
    Default parcle shelf propblems
    ey, i have justr bought 6x9 n i am having difficulties removing the parcle shelf in my vy. is thier a stop to step inctruction manual that anyone can give me or help me in detail? also, do i use a stanley knife to cut the top of the parcle shelf?
  17. #17
    RUN41T's Avatar
    Vy SS
    Jun 2006
    Wollongong
    The perfect senario would be for u to buy a GOOD quality set of 6" splits for the front, mout the speaker in the factory location and the tweeter up high on the dash.
    In the rear u only realy need a pair of fair quality 6x9"s for rear fill.
    I have always been a fan of pioneer head decks but never ofr their speakers, if u spend i little more u could buy some focal access speakers or even lower end boston. These will sound much better off the HU as they are more efficient.
    Down the track look at getting a 4ch amp for the speakers.
    BTW no i wouldnt run 6 speakers off a HU, it is only designed to run 4 max
    My 2c lol
  18. #18
    RUN41T's Avatar
    Vy SS
    Jun 2006
    Wollongong
    I uded a stanley knife, make sure u cut INSIDE the indent for the speaker grille
  19. #19
    JBDrifter's Avatar
    JBDrifter is offline Now in a Calais
    VZ Calais & VT Exec Wagon
    Oct 2006
    The head unit is designed to handle a load of a certain size, usually 4Ohm per channel. Most speakers are 4Ohm, so one speaker per channel is perfect. Running 2 speakers on one channel alters the impedence (resistance) of the load on that channel. Running them in parallel would give a 2Ohm load, thus drawing more current than the head unit is designed to handle. That's where the danger lies. There is a big risk of doing damage to your head unit.
    The only safe way to do it would be running them in series, which is not really recommended. It would give an 8Ohm load, thus not drawing enough current to drive the speakers efficiently.
    If you really want to run 6 speakers then you need amps, a 4 channel and a 2 channel, either daisy chained or use RCA "Y" splitters to get the signal from the head unit to both amps. (Or just a 2 channel for the extra 2 speakers, running the original 4 off the head unit. Or a 4 channel, running 4 speakers off that and 2 speakers off the head unit.)
    Anyway I just thought I'd explain why it is bad to run 6 (or 5!) speakers off your head unit... everyone has just been saying it's bad, now you know why it is bad.
  20. #20
    Lumps of cheese's Avatar
    Lumps of cheese is offline Who wants chowder?
    MY08.5 VE V8 CALAIS/2010 Hilux SR D4 Dual cab 4x4
    Boulder Crusher Champion! Balloon Park Champion! Action Fish Champion! 501 Darts Champion! Frogger Champion! Jungle Kid Champion!
    Nov 2005
    Warrnambool
    You can cut ou the centre section with the stanley knife then cut slots around the lip for your grills, they have tabs on the and you just push the tabs thru the slots and fold them over.
  21. #21
    VY Spac Supercharged L67
    Apr 2006
    NSW
    hey guys just wonder in my vt acclaim i have a pioneer head unit, splis in the front 4 ways in the rear doors a sub and amp in the boot with the splits running off the amp... anyhow i have a set of 6x9's i wanna wack on the shelf would it really matter if i ran them off the amp with the fronts???? only prob will be i wont be able to fade to the 6x9 without splits going aswell!! should i do it???
    i could run both rear doors and 6x9 off amp but then i will have to buy mono block to run sub. by the way my amp is 4ch
  22. #22
    calais_cruzin's Avatar
    calais_cruzin is offline Calais_Rattling....
    92 VP Calais 3.8
    May 2006
    Gold Coast
    6x9 low bass will interferr with the sub,, u will hear the 6x9's wobbling off there head at a low freq, unless u amp them and cut to high freq pass soo no bass is made from them
    ________________________________________
  23. #23
    Apr 2006
    NSW
    yeh i dont want bass from 6x9 just clarity.. do you think it would matter if i just ran them off the amp with the fronts thou???
  24. #24
    92 VP Calais 3.8
    May 2006
    Gold Coast
    what ur system consist of, name everything, amp watts, how stable they are (ohm's) jsut everythink then we can make a decition on if it safe to run them, if u got a amp with 2spare channel it will be fine, but if ur goin run them on the same ch as other speaker are already connected then we will need to find out how stable the amp is.
  25. #25
    2004 Black Vz R8 HSV Clubsport 297kw Gen IV M6
    Apr 2006
    South australia , Adelaide
    im running 4 speakers and 2 subs off my head deck, i dont care if ne thing happens to it gettin a new one in a couple days, but yea nothing has gone wrong or ne thing stuffed up so.
    =Brock=
    My Ride
    2004 Phantom Black Vz R8 Hsv Clubsport 297kw 6L Gen IV M6-6 speed, Full black leather -
  1. VS amp installation
    By vsMick in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-10-2006, 02:22 PM
  2. Amp installation?
    By Philthy in forum Car Audio
    Last Post: 20-09-2006, 07:20 PM
  3. lpg installation
    By stackner in forum General
    Last Post: 05-08-2006, 04:45 PM
  4. CAI installation
    By Haze in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-02-2006, 11:07 PM
  5. Sub installation
    By navyboy85 in forum Car Audio
    Last Post: 08-02-2005, 10:35 AM
