Results 1 to 11 of 11
Thread: amp power cable, No hole in firewall. :(
    phat_com's Avatar
    phat_com is offline VR IS A BEAST WITH NEW V6
    VR s2 Acclaim/VK IS GONE :(
    Jan 2006
    Tuggers (da hood),ACT
    Question amp power cable, No hole in firewall. :(
    Have i am trying to install my sub and amp and can't find any hole in the firewall the run my power cable through
    I have had a good look and have found one just under the fuse box but its packed with the wiring loom and i have found a few around the brake booster but they are behind the dash (speedo) and i can't use them without pulling my dash out (i wouldn't know were to start)
    So where should i run it and can i drill a new hole around the fuse box area and still be able to pass road worthy? you can't cut the parcel shelf the fit 6X9's, so can you drill a hole in the firewall?
    thanks for anyone who replys
    phat_com's Avatar
    Jan 2006
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    There are numerous holes in the firewall, find one with a rubber grommet and cut a slot in it with a sharp trimming knife like a stanley. Poke a feed wire through find it then tape all the wires you want to run to it and pull them through.
    2005 VZ Exec - 95 VS Executive
    Jan 2007
    i was lazy and drilled a hole on the passenger side under the carpet just under the glove box. then i put a bit of silicon around the hole to stop and water and such getting in.
    VR V6 5spd '93
    Nov 2006
    Southern NSW
    1992 HSV SENATOR 5000i
    Apr 2006
    N/W NSW
    Just drill a new hole somwhere out of sight & go to burson/repco & get a wiring grommet the same size. Problem solvered.
    2004 VY2 SV8 A4
    Jun 2005
    Victoria Point, Brisbane
    the clutch cable grommet is on the drivers side near the brake booster. It looks like a pain to get to from inside but with the fuse panel cover removed its not too bad.
    On my cars I use the engine loom grommet on the passengers side because its easiest to get to. Unfortunately its not the easiest to put a hole in as its like 2 inches thick in the centre.
    I bought a cheap and nasty soldering iron from the warehouse and used it to melt a hole through. (taking care not to come too close to the engine loom)
    With a bit of patience, an old soldering iron (it'll be buggered after doing this) and something to lubricate the cable, you can get 4GA cable through the resulting hole without too much pain. I'll post some photos in a minute
    * Phreddy's Blaupunkt Aux input and line out mod
    * 18x8 inch Equus Kalibur Wheels with Maxxis MAV-1 235/40R18
    * Sureflo 3.5 inch medium-loud cat back exhaust
    2004 VY2 SV8 A4
    Jun 2005
    this is the clutch cable grommet that most people use. I am using it to run the vacuum line for my boost gauge.
    Different angle...
    The engine loom grommet. Sorry about the dark photo... I couldn't get a good picture. You can at least see where the red cable disappears into the grommet.
    VY SS
    Aug 2004
    SE Victoria
    Quote Originally Posted by dawg View Post
    yeah thats the way man, did that to me vr this arvo. She be right.
    yeh she will be fine till the silicon wears out and you start blowing fuses and need to replace the whole run of wire!
    VR V6 5spd '93
    Nov 2006
    Southern NSW
    VS Berlina
    Jun 2006
    Lysterfield
    over time the outer layer of the power cable (insulation) will rub against the metal of the chassis. Because the chassis of the car is the negative you will have the positive (power cable) touching the negative (the chase) which will cause a short, and to stop damage the fuses will blow. If a fuse fails to blow it will cause damage to the car.
    So if you drill a hole in the firewall go to Repco or alike and get a grommet to place in the whole to stop wear and tear on the cable.
  1. Putting a hole in the firewall on a VX SS
    By bartman in forum Car Audio
    Last Post: 17-09-2007, 06:25 PM
  2. Running power cable in firewall "VP"
    By wrx884 in forum Car Audio
    Last Post: 07-01-2007, 11:16 AM
  3. Power Cable Through Firewall of VY
    By Exceler8r in forum Car Audio
    Last Post: 12-09-2006, 09:58 PM
  4. getting a hole in a VZ ute firewall
    By CacTuar in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 11-12-2005, 02:59 PM
  5. Clutch cable grommet in firewall
    By Dexn in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-05-2005, 11:05 AM
