hey i need to know where to run the amp power cable to get it threw the fire wall in my 1990 vn commodore cause we cant suss it out i need help asap please
I had that trouble installing one in my cousins vn.
From memory i went to extremes and drilled a hole in the top left hand side facing the car.
i cant do that tho im running the cables now cause the interior is out and its going threw the pits in a few weeks so it needs to be fully roadworthey eny ideas please i herd of maybe the clutch cable holl that isnt used cause mine is auto
not sure if its the same on the vn........but on my VP i am running cable threw a hole in the firewall which is sort of just behind the washer water resevoir and below..........
hey thatx ppl i found a gromett behind the brake booster and got it threw there cheers tho
