Results 1 to 3 of 3
Thread: removal of single DIN head unit VT2
    vt acclaim S2
    Mar 2007
    Default removal of single DIN head unit VT2
    Hi,
    I bought the VT with the original head unit replaced with a single din unit and a storage tray underneath. I have read how to remove the original unit with special tool/coathangers etc, but I can't figure out how to remove this one (Kenwood KDC 1016) or the tray underneath - there are no holes to push tools into. There is a plastic surround around the headunit, but I cant see how that comes off. Can anyone help?
    Thanks.
    SweetWagon's Avatar
    SweetWagon is offline booosted
    VS Berlina Wagon Supercharged & VU SS Ute
    Jan 2006
    Springwood NSW
    the plastic tray underneath just clips in, it will come out if you give it a good tug, you need the two little "keys" to get the h/u out assuming it was put in correctly, the plastic surround also simply clips on and off (with face detached) which will give you access to where the keys go. you should be able to see how the h/u its mounted in when you remove the plastic tray.
    VYII SV8
    Aug 2006
    Toowoomba
    Just to clarify.....
    Officially, you should remove the head unit first. To do this, first remove the head unit face (if possible) to prevent scratching it. There's normally a plastic trim panel around the outside of the head unit, and this can be removed by squeezing in the right place and gently pulling. You may need to experiment with what seems to work, because they're all different. Once you have the trim piece off, you should be left with the metail "cage" with the head unit sitting in it. There will be 2 thin slots on the side, and you need to insert 2 keys into these slots to un-clip the head unit. It seems all the keys are pretty much the same, so any brand will do. Usually you can just fully insert the keys and then pull back - the head unit will unclip and slide out as you pull.
    If you don't have the keys, you may need to resort to pulling the whole plastic panel out. This may prove difficult since there's not much to hang on to, but the fascia panel just clips in and should come free with a good firm pull. You should then be able to access the rear of the head unit.
  1. Head Unit Removal
    By nvs_sle in forum VL Holden Commodore (1986 - 1988)
    Last Post: 01-11-2006, 12:34 AM
  2. head unit removal
    By scolari in forum Car Audio
    Last Post: 12-12-2005, 07:05 PM
  3. Removal of VZ Head Unit
    By vzuterus in forum Car Audio
    Last Post: 16-10-2005, 04:54 PM
  4. VK head unit removal
    By sandman_538 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 09-10-2005, 12:06 PM
  5. VY Head Unit single disc
    By RichardW in forum Parts And Other Items For Sale
    Last Post: 03-09-2005, 02:24 PM
