Results 1 to 11 of 11
Thread: Clarion Amp Setup
    VS V6 Duel Fuel Exec
    Feb 2006
    Unhappy Clarion Amp Setup
    hi
    i have a boss amp which i want to use to run my 6" fronts and 6"x9".
    the problem is that there is only two RCA outputs from my Sony headunit and there is four inputs on the amp.
    how do i connect up the amp so that i can use all four channels?
    cheers
    edit:just noticed that i put clarion in the heading.the amp is a Boss.
    Cobez's Avatar
    Cobez is offline LS-EXUAL
    2004 S2 VY SS Ute
    Feb 2007
    generally when u run ampS and stuff in your car u need to get a headunit with 3RCA output.............
    Feb 2006
    yeah i know.
    but im a uni budget which means that i need to make do with with what ive got. i picked up an amp off a mate for really cheap and i just want better SQ outa my my el-cheapo setup and wiring up the amp was confusing as havent had much to do with amps. i wish i could afford a new H/U but i cant.
    Phreddy's Avatar
    Phreddy is offline Bye SV6 - still love you
    VS-II Statey-8
    Apr 2005
    W-Sydney NSW
    Just get a couple of "Y" cables (a single female socket running to two plugs) - at the amp end, connect these between the ends of your RCA leads, so it splits out as two left and two right channels. You won't have a front/rear fader function, but at least you'll get all four channels of the amp being driven.
    Cheerz!
    New look ASR Website online now!!
    www.asr-audio.com.au
    Interior lighting and audio specialties
    for VT/VX & VY/VZ Commodore / Monaro
    NOW VE DASH LIGHTING CONVERSIONS!!
    PLUS TECH2 DIAGNOSTIC SERVICES
    JBL Car Audio dealer
    Feb 2006
    thanks phreddy. the y pieces sound like the go.i had a suspision i might have o use these so ill get some.
    thanks mate
    Phreddy's Avatar
    VS-II Statey-8
    Apr 2005
    W-Sydney NSW
    A pleasure! Good luck with it.
    wrx884's Avatar
    wrx884 is offline WA's ASR Rep
    VT Commodore Exec/5L VP Calais
    Mar 2006
    I had the same set up in my old magna hahaha miss the old girl the HU only had 1 pre out but i had 2 run the 2 Y spliters 2 amp up front and rear 6x9's then had another 2 ch boss amp 2 run a 12" sony xplode (see my ride was in the VT 4 a month) till i upgraded best budget if u just want doof doof and dont care bout SQ as they pump just as loud as most
    oh btw boss amps rnt all that great just keep an eye on em from time 2 time they have a tendancy 2 get faulty tho in sayin that my amps n sub is in a cuz's car same reason and still goin hard quite funny really wen u hear stories from other ppls boss stuff up lol
    Check out my ride in progress.... 98 VT V6, V8 Supercar kitted
    Daily toy.... 92 VP Calais 5L
    Feb 2006
    yeah i know boss amps arent very good or reliable but this one will do until i can save up to get a jaycar responce amp.im not after excellent SQ, just better than stock.
    Phreddy's Avatar
    VS-II Statey-8
    Apr 2005
    W-Sydney NSW
    Hey Ant - you MISS a Magna??
    You'll have to shoot straighter then....
    VN V6 Manual
    Mar 2007
    The South
    Left channel for front speakers split to channel 1 and 2. Right channel for sub output bridging channels three and four. RCA splitters are under $10 each.
    Make sure your sub is running at 4ohm also... those boss amps dont like 2ohm loads much, easy to fry them.
    1989 VN 5 Speed – Turbo conversion
    1997 BMW E39 M52B25 Powered.
    1994 Yamaha XT225 Modified
    wrx884's Avatar
    Mar 2006
    Quote Originally Posted by Phreddy View Post
    hahahahaha i'll keep that in mind next time
  1. FS VIC - 2 Clarion subs in box with Clarion amp - $250
    By DaRiO in forum Parts And Other Items For Sale
    Last Post: 31-10-2007, 11:02 AM
  2. Clarion V-net Subs
    By 5speedcalais in forum Car Audio
    Last Post: 24-12-2006, 01:06 PM
  3. VK Stock drum and disk setup to a VT disk setup
    By justinp in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 19-02-2006, 09:37 PM
  4. Clarion Sub
    By tr3nt in forum Car Audio
    Last Post: 24-10-2005, 09:03 PM
  5. Clarion Setup
    Last Post: 26-07-2005, 08:32 PM
