Results 1 to 22 of 22
Thread: Not saving audio settings?
    '97 VS II Statesman 5.0L 5-Speed
    Feb 2006
    Radelaide
    Default Not saving audio settings?
    hey everyone having a problem with my head unit..
    its not saving my audio settings (Bass, Treble, Sub, Midrange etc) when i turn the car off and on, i have to redo all my settings.
    also whenever i turn my car on, my head unit comes on Standby, and i have to change it to CD/USB/Radio or whatever i want to listen to.
    but it still saves my radio station presets.. so i dont know whats going on
    thanks in advance for any help.
    R Photon's Avatar
    R Photon is offline I Like Bresciani Racing
    1990 VN Commodore
    Nov 2005
    Brisbane,Queensland
    what type of head unit do you have?
    <<DRIVE IT LIKE ITS HOT>>
    "Calais, interior is rezzed, mess my interior, its suicide you d!ckhead"
    pr0n's Avatar
    pr0n is offline It's A Me ' MARIO '
    03 VY II S V6
    Dec 2006
    Gladstone
    12v and accessory wire around the wrong way, just change the red and yellow ones around.
    and maybe the reason it saves the radio station is because it has an internal backup battery.
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    pr0n's Avatar
    03 VY II S V6
    Dec 2006
    Gladstone
    R Photon, it doesnt matter which headunit cause like 99% of all headunits use the same wiring colours.
    sganro is offline i speak before i think
    yet another VS
    Aug 2005
    NQ
    Quote Originally Posted by pr0n View Post
    i thought all the settings were saved off constant power, but im not an expert in this area so it could have an internal battery
    There are no stupid questions, just stupid people
    pr0n's Avatar
    03 VY II S V6
    Dec 2006
    Gladstone
    im no expert either but i know my old sony one had an internal battery cause it would remember stations even when removed from the car. it lasted about 2 days and then it forgot them.
    VN V6 Manual
    Mar 2007
    The South
    Quote Originally Posted by Not_An_Abba_Fan View Post
    And make sure the yellow wire is constant power.
    Yellow: + Battery wire
    Red: Accessories from like cig lighter or somewhere...
    1989 VN 5 Speed – Turbo conversion
    1997 BMW E39 M52B25 Powered.
    1994 Yamaha XT225 Modified
    Feb 2006
    Radelaide
    2003 VY S1 Commodore Berlina sedan
    Oct 2005
    Wellington, New Zealand (Yes i know yet another KIWI)
    I have the same problem in my VY, i have got a wiring harness from the stock wiring to my sony head unit, i have swapped over the red and the yellow wires and it is keeping its settings but now when i turn off the car the stereo keeps going buy itself.
    Anyone know how to fix this?
    Feb 2006
    Radelaide
    turn the head unit off when you turn your car off.. that can actually be pretty handy if you want music when the cars off you dont need to put accessories on you just turn it on
    Feb 2006
    Radelaide
    well that didnt work, i swapped them over and it just does the same thing but makes a buzzing sound when it turns on like its searching for a CD..
    if it makes a difference i have a Kenwood KDC-X7533U
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Faulty head unit perhaps? Is there a troubleshooting guide in the manual?
    Feb 2006
    Radelaide
  15. #15
    VN V6 Manual
    Mar 2007
    The South
    I always run a new positive power wire to the battery... then find an ACC wire source from the original wiring. Make the positive power wire black also, if you want it unnoticeable in the engine back.
  16. #16
    VY SS
    Feb 2007
    Atherton, North Queensland
    Yea i had the same problem, all i had to do was switch the 12v wire and the acc wire around
  17. #17
    Feb 2006
    Radelaide
  18. #18
    Tasmaniak's Avatar
    Tasmaniak is offline Not a valid input....
    car
    Apr 2005
    VK_308 Sorry to say that it IS a faulty headunit, seems something happened inbetween R&R. Live with it or replace it.
  19. #19
    Feb 2006
    Radelaide
    well im not very good with wiring is it possible i've put 2 accessories wires instead of one accessories and one 12v? or would it not even power up then?
    it worked perfectly fine in my old car the same day i put it into my new one ...
  20. #20
    Tasmaniak's Avatar
    car
    Apr 2005
    You see, the reason I can tell you it's not the wiring is simply because it's remembering the radio presets. If it doesn't have constant power to it, it won't hold the audio settings like it's doing but it also won't hold radio stations which it's doing.
    If you had your wiring mixed up, then it wouldn't even remember them. But you see, it's remembering something.
    I'm sorry, but I don't have anything else to tell you. The only other thing I could think of is perhaps a setting in the CD Player itself.
    Maybe StoneX might be able to provide some insight but I've never heard of wiring causing an issue like this.
  21. #21
    Feb 2006
    Radelaide
    the thing is its not remembering the radio stations i set.. its like its just scanned the stations and remembered the ones that popped up.. lucky for me the stations i listen to are on it so i dont bother stuffing around with it
  22. #22
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    That is part of the scan process, it automatically stores them once it has found them. Once you turn your key off does it lose those presets and then needs to scan again? Try running a separate fused wire from your battery to the memory(yellow) wire and see what happens.
  1. daylight saving
    By R0d in forum The Pub
    Last Post: 04-12-2006, 10:53 PM
  2. Saving Video's off YouTube...
    By Frandy in forum The Pub
    Last Post: 05-09-2006, 10:27 AM
  3. Saving $$$ with engine flush
    By 88GreenVN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-07-2006, 07:22 PM
  4. Life Saving First Aid
    By SLugg in forum Jokes/Humour
    Last Post: 18-04-2006, 11:17 PM
  5. What are you saving up for?
    By Troy711 in forum The Pub
    Last Post: 30-09-2004, 11:28 AM
