Results 1 to 12 of 12
Thread: What amp for 2 Rockford Fosgate subs
    VX Senator Signature
    Feb 2006
    SHL NSW
    Default What amp for 2 Rockford Fosgate subs
    Looking at 2 Rockford Fosgate 8" subs for my parcel shelf, 50-200wrms 4ohm dual voice coil.
    What would be the best amp? Do i need a two channel to wire them seperatley or a mono block and running on the same output. Im a little confused with the ohms and dropping when running two on the one amp? Anyone know what im talking about??
    Thanks
    -Dave
    VS Berlina
    Jun 2006
    Lysterfield
    When you run speakers in your case subs in series, it will halve the resistance (ohms) causing the two 4 ohm subs to become 2ohm. This will allow more power to pass through them and in turn making them louder. That is my basic understanding I'm sure one of the tech heads here will give the the correct rundown.
    To run them in series just connect the + of one sub to the - of the other, then the remaining terminals to the corresponding outputs on the amp.
    ie.
    (-)SUB 1(+)---(-)SUB 2(+)
    I____ (-) AMP (+)_____I
    2004 VY2 SV8 A4
    Jun 2005
    Victoria Point, Brisbane
    Quote Originally Posted by Shaneus View Post
    ie.
    You've got that backwards... series connection will add their impedances, and parallel will split them.
    If you have two four ohm subs and connect them in parallel (that is... the positive lead of each sub connects to the positive terminal of the amp and the negative lead of each goes to the negative of the amp) then the impedance as far as the amp is concerned will be 2 ohms. Make sure that the amp is capable of driving a 2 ohm load or you could potentially damage it, or at best, it could cut out or not work at all.
    * Phreddy's Blaupunkt Aux input and line out mod
    * 18x8 inch Equus Kalibur Wheels with Maxxis MAV-1 235/40R18
    * Sureflo 3.5 inch medium-loud cat back exhaust
    Feb 2006
    SHL NSW
    Ok thanks, makes sense.
    So i can run 2 x 4ohm subs parallel to a mono block as long as it can handle 2ohms.
    2004 VY2 SV8 A4
    Jun 2005
    sure can
    Feb 2006
    SHL NSW
    VS Acclaim
    Jun 2006
    Quote Originally Posted by DavoX7 View Post
    The subs are 4 ohm DVC - if you wire all the coils up in parallel you will be providing a 1 ohm load - not good unless you wanna pay for an amp which is 1 ohm stable.
    If you only manage to get an amp that is only two ohm stable, you will be forced to wire your woofers at 4 ohm. This can be done by wiring in parallel between woofers, and in series between coils (wiring in series between woofers is not advised due to the potential noise created by background emf)
    Conversely, you can pick up a 2 channel amp and run one woofer per channel at 2 ohms.
    If youd like give us a budget and we can recommend some amps to consider
    Attached Thumbnails Attached Thumbnails What amp for 2 Rockford Fosgate subs-2_4ohmdvc_1ohm.gif   What amp for 2 Rockford Fosgate subs-2_4ohmdvc_4ohm.gif
    2004 VY2 SV8 A4
    Jun 2005
    DAMMIT I missed the word "dual"... that changes the rules completely!
    +1 for Joe Peeps
    DANNY8's Avatar
    DANNY8 is offline Yo Coooornflake!
    VT SS 5.0L, VK WAGZ 5.0L
    Apr 2004
    Port Pirie, South Australia
    I thought when u wire up subs in a series, the + from the amp goes to the + on the first sub, then from that to the other + on the other sub, and same for the -? Like all the +'s are connected, and all the -'s.
    I had a JL 4ohm amp, and 2 JL 8ohm subs and that's how I was told to do it...is that right or wrong?
    VS Acclaim
    Jun 2006
    Thanks Shaggerz, easy to miss that going by the other posts
    VHPirie -
    Quote Originally Posted by shaggerz View Post
    you had it wired up correct for your application, only the nomenclanture is wrong. That wiring is parallel wiring
    Series wiring would be from amp + to sub 1 +, sub 1 - to sub 2 +, sub 2 - to amp -. This has the effect of adding all the ohms, so if you did wire in series youd be showing the amp 16ohms with your 2 JLs.
    Feb 2006
    SHL NSW
    Im looking to spend somewhere around the $500 mark on the amp. Maybe more if need be.
    If money was no object for the amp, what would be the best way have it set up? The 2 channel amp seemed the easiest way to me actually. But being dual could a 4 channel even work?
    Just when i thought I understood....
    -Dave
    VY SS
    Aug 2004
    SE Victoria
    dave, get a class d amp (aka monoblock). they are suited to subs and are more efficent.
    look at getting something that outputs 400Wrms at 4 ohms (2x200Wrms subs). spend how ever much you want upwards of $400 will do it.
  1. rockford fosgate sub 10inch
    By CAM05L in forum Parts And Other Items For Sale
    Last Post: 17-01-2007, 02:43 PM
  2. Rockford Fosgate amps!!!
    By [SIK-GMH] in forum Car Audio
    Last Post: 07-08-2006, 09:59 PM
  3. rockford fosgate
    By mortivivosdocent in forum Car Audio
    Last Post: 20-07-2006, 07:51 PM
  4. Rockford Fosgate
    By Spanner in forum Car Audio
    Last Post: 20-12-2004, 04:44 PM
