Results 1 to 17 of 17
Thread: Box Volume Calculations
    2004 VY2 SV8 A4
    Jun 2005
    Victoria Point, Brisbane
    Default Box Volume Calculations
    Hey guys,
    Although normally I do my research and find out these things for myself, I already have about 2000 hobbies so I thought I'd just ask here.
    I want to build a properly tuned ported enclosure (i have always just used sealed but its time for a change) for my sub when I do the boot install properly.
    Question 1: as long as the box volume and port size remains constant, will it be OK to change the dimensions of the enclosure as long as I maintain that correct box volume and port size?
    Question 2: what are the rules for the position of the port?
    Here are the thiele small parameters for the driver I'll be using. It's a Response 12 inch DVC. These are given assuming voice coils connected in parallel for a 2 ohm load.
    Dc Resistance: 1.7 ohms
    Vas: 79.454L
    Qms: 3.238
    Qes: 0.446
    Qts: 0.392
    Sensitivity: 88.192 dB @ 1 watt & 1 metre
    BL: 9.992TM
    Fo: 28.77Hz
    Sd: 514.72 sq cm
    Can someone clever please work out the ideal box volume and port size for this driver??
    Thanks!
    * Phreddy's Blaupunkt Aux input and line out mod
    * 18x8 inch Equus Kalibur Wheels with Maxxis MAV-1 235/40R18
    * Sureflo 3.5 inch medium-loud cat back exhaust
    Phreddy's Avatar
    Phreddy is offline Bye SV6 - still love you
    VS-II Statey-8
    Apr 2005
    W-Sydney NSW
    Hiya Shagz.
    Mate, I've done the calcs for this driver before and this is what I came up with.
    Cabinet volume - 50 litres
    Port diameter - 2 x 66mm
    Port length - 191mm
    3dB frequency - ~36Hz
    As far as box dimensions go, some folks talk about the "golden figures" but I found they're not absolutely critical. Just don't forget to allow a bit extra for the back-volume of the driver (probably about 3 - 3.5 litres), plus any bracing you'll be using. As far as the port location goes, just make sure they're not within about 100mm of the driver, and that the inside ends of the ports are well away from any of the internal surfaces. Oh, and don't forget to subtract the port volume from the box as well - the air inside the ports can't be considered as part of the box volume itself.
    Cheerz Mate, best of luck with it!
    New look ASR Website online now!!
    www.asr-audio.com.au
    Interior lighting and audio specialties
    for VT/VX & VY/VZ Commodore / Monaro
    NOW VE DASH LIGHTING CONVERSIONS!!
    PLUS TECH2 DIAGNOSTIC SERVICES
    JBL Car Audio dealer
    2004 VY2 SV8 A4
    Jun 2005
    thanks champ
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    Answer 1: Yes, box shape can be whatever as long as volume stays the same.
    Answer 2: The port SHOULD be on the same wall as the sub, but it's not essential, just make sure the sub and port are in the same area, so no venting ports through parcel shelves or through the ski port between the seats.
    sganro is offline i speak before i think
    yet another VS
    Aug 2005
    NQ
    I have seen audio software that you input your speaker info and it generates ideal box volume, port size etc. Not sure how hard it would be to find but it might be helpful if you could find a similar program. Good luck
    There are no stupid questions, just stupid people
    Phreddy's Avatar
    VS-II Statey-8
    Apr 2005
    W-Sydney NSW
    Ummmm - yeah, that's what I used...
    There are a few out there, some contenders are Abacus, WinSpk, WinISD, and of course BassBox. (many others, but....)
    Shagz' point was that he had enough hobbies without having to learn to drive yet another piece of software. Good suggestion though...
    Cheerz!
    2004 VY2 SV8 A4
    Jun 2005
    I tried WinISD but when it wasn't painfully obvious to me I gave up
    calais_cruzin's Avatar
    calais_cruzin is offline Calais_Rattling....
    92 VP Calais 3.8
    May 2006
    Gold Coast
    I got bass box pro 6, havnt accually put it to use yet, but did have a fiddle around with it and seems to be very easy to use.
    Does everythink, that i saw anyway, and have box shape chooser and has the measurements of everythink.
    I cant wait to make up a box for my boot, should be alot of fun.
    ________________________________________
    Phreddy's Avatar
    VS-II Statey-8
    Apr 2005
    W-Sydney NSW
    BB Pro is real good. I used WinISD for the calculations above, it's always done well for me - and the price is right!!
    2004 VY2 SV8 A4
    Jun 2005
    OK guys heres my design. These are inside dimensions and the value of x will be calculated so that the volume = 50 litres with bracing, port, and driver displacement subtracted.
    The angled side (the back) of the enclosure will be up against the back seats, with the face side facing into the boot void. The "face side" as marked will have a false wall for the boot attached. It will be the side with the driver and ports mounted to it, facing towards the rear of the car.
    You guys foresee any problems with that design?
    SoulGrind's Avatar
    SoulGrind is offline §ôµÏG®ïñD
    VH SLX - VX SII Calais
    Aug 2004
    VY SS
    Aug 2004
    SE Victoria
    Quote Originally Posted by Phreddy View Post
    yeah bloody oath the price is right, why pay for bbpro when winisd is free?
    vt acclaim
    Nov 2006
    ive run that same sub in a ported enclosure built to the specs by a helpfull member from CAA, I found the sub to sound better in sealed application, I have mine in a sealed enclosure around 40l powering it at 600rms@2ohms and im happy with it
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    Quote Originally Posted by garfa View Post
    Because they give different results... Only one can be right and I'd rather trust the one the pros pay for and use rather than the freebie from the internet.
  15. #15
    vp v6 commodore executive
    Aug 2006
    south island newzealand
  16. #16
    Tasmaniak's Avatar
    Tasmaniak is offline Not a valid input....
    car
    Apr 2005
    don't you have a version of BBpro?
  17. #17
    VY SS
    Aug 2004
    SE Victoria
    stonex: if you are going to get the price you pay for BBPro back in use or improved quality then yes i would go for it. but myself and i am sure many others cannot be bothered effectively wasting the price of BBPro for that small improvment.
    ray: yeah just never got around to installing it. winisd did it for me.
  1. maximum volume is crap...
    By ~shellee~ in forum VY Holden Commodore (2002 - 2004)
    Last Post: 02-06-2011, 01:28 PM
  2. oil volume
    By VTPREDATOR in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-10-2007, 02:37 PM
  3. Anyone seen new radios with volume on right side?
    By holdenrules in forum Car Audio
    Last Post: 18-04-2007, 12:05 PM
  4. Gday and oil volume
    By wethepeople in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-12-2006, 07:14 PM
  5. Audio Volume
    By Shivaga in forum Car Audio
    Last Post: 06-10-2005, 01:56 AM
