you can and you can't....The headphone output on an MP3 player is a much higher output then what the Input on the amp can handle.
If you keep the volume WAY WAY WAY down low on the MP3 player then you could do it.
My honest suggestion would be to Hi-Lo convertor and then use it the volume at will. I would imagine a regular Hi-Lo convertor would be sufficient. Perhaps StoneX could tell us more.
The amps input threshold is measured in mW where as the headphone output on an MP3 player is about .5W
The only other option I could think of is if the MP3 player had a line out option like the iPods do for connecting it to Aux Inputs.
LinkBack URL
About LinkBacks
