hey i just put a pioneer head unit in my datsun ute. It worked good for about 2 weeks and now theres no sound.
THere is power going to the head unit coz it lights up and reads the disc and stuff but theres no souhd comin out of the speakers!?!?![]()
any ideas??
cheers
speaker wire connections dodgy? Try disconnectiong the power to reset it.
one of the spek terminals is touching ground/earth
if you cut a hole in door to fit spkr remove and retest
when a spkr wire/terminal gets grounded the unit shuts down but looks like its still on
its a safty thing
maybe one of your speaker wires is short circuting check that your speaker wires arnt touching (+ touching -) if they are it puts the head deck into safety mode and it wont have sound...
Check for those, But if there is no problem there take it out and go get the desk fixed. Pioneer have that problem
it wont be the deck its 2 weeks old
pioneer have a very rep for their stuff working for more than 2 weeks
Pioneer have that problem? Thats news to me too. Can you tell us why you think that?
Pioneer dont have that problem.
Its the installer that has the problem.
As has been said above, the speaker wires are shorting out, as for us to tell you which well youll have to pull out the deck make sure everything is soldered and insulated properly, and if you ran wires thru places where it can jam and cut thru the wire then perhaps time to reroute the place where the wires run.
To find which speakers are causing the issue.
Remove one pair from the back of the unit. Switch radio on. No sound still? Turn off Radio and remove another pair of speakers? Continue on through the speakers until it's fixed.
I wonder if this was a common earth situation?
Also, the longer the wiring is stuffed, the more likely it is that the head unit will be damaged... So you could disconnect all the speaker wires and test it and it'll still have no sound because the internal amp might have been blown. Most of the time, the IC protection does it's job though and just mutes the chip to prevent damage.
V8 Berlina is probably a big red chain store installer, they seem to send more working head units in for repair than faulty ones.
